Hijet no warm air.
Page 1 of 2 1, 2  Next
Hijet no warm air.
Post by cmorse on Wed Oct 17, 2012 4:19 pm
Hey guys,
Ive had my hijet for a month now and its blowers have been working fine. Hot air coming out to clear the windscreen and warm my feet. However its now not working at all. Any ideas what might have stopped them?
Thanks,
cmorse
Re: Hijet no warm air.
Post by elfin girl on Wed Oct 17, 2012 5:44 pm
Thermostat stuck open?
Post by Logi on Wed Oct 17, 2012 5:49 pm
Not blowing or blowing cold air?
Post by elfin girl on Wed Oct 17, 2012 6:01 pm
Oh, and what's the temp gauge doing?
Post by HighlyJetted on Wed Oct 17, 2012 6:52 pm
Logi wrote:Not blowing (any air) or blowing cold air?
Yep, good question.
Post by PFM on Wed Oct 17, 2012 7:04 pm
I'll guess it's not blowing on any speed setting: check fuse first.
Post by toastiee on Wed Oct 17, 2012 7:18 pm
hope know one minds me asking here instead of a new thread ? Smile i get warm up top and down below but the vents that stick out the dash are always chilly . is that normal ?
ta D
toastiee
Post by elfin girl on Wed Oct 17, 2012 7:28 pm
oops, dont know what i did there, just deleted post!
ther is a "door" behind the ones on the dash, maybe the lever has become disconected or something
Post by toastiee on Wed Oct 17, 2012 7:40 pm
how do you control the door ? is it just from the heater controls ? can you make warm come out them ? if not i shall block um um for the winter Smile cheers d
toastiee
Post by Logi on Wed Oct 17, 2012 8:00 pm
toastiee wrote:hope know one minds me asking here instead of a new thread ? Smile i get warm up top and down below but the vents that stick out the dash are always chilly . is that normal ?
ta D
Same here
Post by HighlyJetted on Wed Oct 17, 2012 11:35 pm
My middle vents only blow cold too.
Post by elfin girl on Wed Oct 17, 2012 11:41 pm
ok, trying to put some labels on a picture of whats under the dashboard, but i dont have a program i can do it in, anyone know of a quick freebie i can downlad?
Post by elfin girl on Wed Oct 17, 2012 11:56 pm
did a crude one in paint!
1 = lever and "door" to direct heat from inside or outside
2 = lever which controlls where your want the air blown, and the door that opens when its set to the first or second setting, it is controlled by cables, if i remember rightly a bit like the ones that controll gear leavers on a push bike, maybe the cable has detatched, or the door has broken?
3 = these tubes slot into the bottom inside of the dash to direct the air through the vents onto windscreen
there is more going on inside behind the doors, but i dont have any pictures of this, i dont remember there being anything that moves with the levers, and much as i now wish id paid a bit more attention... im not taking the dash off again!!!
Post by elfin girl on Thu Oct 18, 2012 12:05 am
under the rad (circled) is the gadget that is cotrolled from the heater lever, if the cable comes detached you will either have always cold air or always hot air dependin on what position it was when the cable came off, you cant actualy see the cable here, it is obscured by the sponge on the left, but again its like the cables on a push bike
http://i33.servimg.com/u/f33/17/63/95/76/under_10.jpg
Post by HighlyJetted on Thu Oct 18, 2012 12:09 am
Download GIMP (Graphical Image Manipulation Program)
It's like photoshop but opensource and 100% free
http://www.gimp.org/downloads/
Post by elfin girl on Thu Oct 18, 2012 12:13 am
cheers hj, ill do it tommorow!
and do you know what, its been so long since my van worked properly im now wondering if i get hot air out of the dash now!!!
Post by cmorse on Thu Oct 18, 2012 11:36 am
Hey guys thanks for all the replies! Its actually not blowing any air on cold or hot or any setting. Is this more likely to do with the fuse?
Where can i locate it?
cmorse
Post by PFM on Thu Oct 18, 2012 1:19 pm
The fuse is in the fuse block below the dash, about 10" above the clutch pedal. You'll see the symbol for a fan on the cover, fuse should be directly behind that.
Post by PFM on Thu Oct 18, 2012 1:23 pm
Mine's the same. The handbook isn't very clear on this, but I think it suggests the dash vents are for ventilation, thus unheated, and the screen and lower outlets are for heating.
Post by toastiee on Thu Oct 18, 2012 8:31 pm
daisydon wrote:ok, trying to put some labels on a picture of whats under the dashboard, but i dont have a program i can do it in, anyone know of a quick freebie i can downlad?
http://pixlr.com/editor/
this site is well handy , edit pics on line instant and free Smile
toastiee
Post by cmorse on Fri Oct 26, 2012 12:49 pm
Hey Guys so ive put a new fuse in but still not blowing either hot or cold air. Any more ideas? thanks for the help so far!
cmorse
Post by PFM on Fri Oct 26, 2012 2:07 pm
So the fan still isn't working - on all speed settings?
Post by cmorse on Fri Oct 26, 2012 2:30 pm
Yeah its not working on any speed settings or on hot or cold. Im getting a faint bit of warm air coming out of the windscreen blowers and foot blowers when nothings on, so there is a bit of temperture heating through.
cmorse
Post by PFM on Fri Oct 26, 2012 2:41 pm
Blower action and air temperature are 2 seperate things. Air is warmed as it goes through a small radiator behind the dash (heated by water in the engine), and you'll get a small amount of air through when driving due to the van pushing through the air. When you turn the temperature lever to cold, air coming into the van doesn't go through this radiator.
When you turn on the blower, the incoming air is pushed faster into the van, irrespective of temperature setting. It's like the cooling fan on a car's radiator. The more air that passes through the radiator fins the more heat it absorbs, cooling the water in the rad.
So if it's not the fuse you must have a problem with the wiring to the blower or blower switch, or the actual motor that drives the blower fan. I think I'd start with the switch first, check there's power to it.
Post by HighlyJetted on Fri Oct 26, 2012 5:59 pm
Right then, so the fans don't work. This is going to be one of 3 things, most likely 2 of them from what your saying.
If it worked on some speeds and not others I'd say its going to be the switch or the resistor pack. But it doesn't work at all so....
If it works on no speeds at all then its either the fan motor or the resistor pack. (unless it's something to do with power to the whole system e.g. fuse or broken wire)
So the first item to visually inspect is the resistor pack in my opinion which is a simple task.
It is bolted into the drivers side of the heater under the dashboard, it has a 10mm bolt holding it in from memory, and it has an electrical plug going into it with I think 4 wires.
Unbolt and unplug it, and have a look at the little coils of wire, I bet one of the main ones has burnt out. If this is the case I have a spare one Laughing
Other than that simple check, and pulling the heater control panel off to make sure non of the plugs have come disconnected which I doubt, its a case of doing some electrical fault finding e.g. make sure there is power going to the switch, make sure the switch switches ok, then make sure the power is getting to the fan motor etc etc.
Post by HighlyJetted on Fri Oct 26, 2012 7:04 pm
Right forget most of that, I've just taken a fan speed resistor out of my parts van to double check what I've said and it's not entirely correct!
This is the wiring layout for the heater fan system :-
As you can see, if it was the resistor pack at fault top speed would still work.
So the fault must be somewhere in the switch or the motor or the fuse or wiring - to pin it down!!
So to test with your multimeter, put it on the volts mode, and see if your getting 12v where the fuse plugs in, if that is ok move onto the next step.
Now take the centre bit of the dash board off, unplug the fan switch connector and make sure three of the pins get 12v (all of them except the white and black wire which is ground), and the white/black wire should give you continuity down to the chassis ground.
If your not getting all three of the 12v feeds to the switch, it says either the fan is duff or the wiring from the fuse to the fan is at fault.
If you don't get ground continuity on the white and black wire at the switch plug the ground is at fault.
If all of these test are ok, then the switch is at fault. (funnily I have a spare one of these (shameless plug)) Wink Laughing
Now all that aside, if you want to see a good fan speed resistor it should look like this:-
But if you ever need to take it out a word of warning, its a right bloody arse!!! You have to take the clocks out to get to it then struggle like hell.
Hope this gets you fixed.
Post by rich the mechanic on Fri Oct 26, 2012 7:54 pm
I might actually look this weekend to see if my resistor pack has burnt out as setting 1 stopped a couple of months back. HJ can you give us a resistance reading from both coils please.
Post by HighlyJetted on Fri Oct 26, 2012 8:33 pm
I sure can, but really you just look at them and see one coil that has a bit missing. I've locked up my garage for tonight but I'll test it out tomorrow and post up the readings.
I've changed them on lots of cars before, the ones that are a pain are the modern ones that use pulse width modulation (pwm) instead so they use a mosfet transistor and a pile of complicated electronics. Heres one I fixed on a peugeot 406 hdi estate about a year back:-
http://www.bargainspares.com/peugeot-406-heater-blower-fan-always-stuck-on-how-to-fix-the-controller-resistor-pack/
Post by HighlyJetted on Fri Oct 26, 2012 8:56 pm
1.2 ohm and 2.4 ohm, I think, but its pretty hard to get solid reading of them.
Robbed daisyd's picture as it shows the resistor pack. But so you know, you can't get to it via the little panel on top of the dash as I tried that first.
Post by rich the mechanic on Fri Oct 26, 2012 9:08 pm
Was thinking about replacing the burnt out coil with a ceramic on a heat sink as I can get them from maplins or if not then I can butcher one from something else to get the fan working was even considering a sliding pot and having a range rather than a choice.
