Hijet no warm air.
Page 2 of 2 Previous  1, 2
Re: Hijet no warm air.
Post by HighlyJetted on Fri Oct 26, 2012 9:39 pm
Doing a bit of P = I x V on it gives you some problems with resistors...
Taken from the 20 amp fuse rating
20amp x 12volts = 240watts
It'll be less than that, say 15amp instead you still get 180watts
That's why they use air cooled coils as the resistors as they carry alot of current running a fan blower motor.
Post by rich the mechanic on Fri Oct 26, 2012 9:46 pm
Iwas opting towards the ceramic with the heatsink but a butchered coil from something more readily available will work.
