Drainage plug gaskets??
Post by stevelav on Sun Nov 04, 2012 2:43 pm
I can't find an oil sump plug gasket, a diff drain plug gasket or a gear box drain plug gasket online?
What do you guys use something like locktite gasket maker or do you just have ones of the approx size or do you reuse the old ones?
Stephen
stevelav
Re: Drainage plug gaskets??
Post by rich the mechanic on Sun Nov 04, 2012 2:53 pm
They are usually copper washers which you can reuse if you have a leak you can carefully wrap the head end of the bolt with PTFE tape just make sure you don't get a loose bit inside.
Post by HighlyJetted on Sun Nov 04, 2012 4:17 pm
Or walk into your local nuts n bolts engineering shop as they will carry copper washers in loads of metric sizes.
Post by stevelav on Sun Nov 04, 2012 8:01 pm
ptfe tape it is then as unfortunately by the time you find out what size washer you need its a bit too late to get one
stevelav
