Dashboard lights
Dashboard lights
Post by SUSIE on Sat Feb 20, 2010 7:15 pm
Hi any ideas how to get to those very dim dash lights?
SUSIE
DashBoard Lights
Post by rich the mechanic on Sun Feb 21, 2010 10:39 am
Hi get hold of the trim and pull then you can see the screws can be done with the steering wheel on but a bit awkward then you have to reach round and unplug the two connector then you have the cluster out and can go back to the warm and unscrew your way in not a big job but fairly easy to see once you have the trim off.
Re: Dashboard lights
Post by bikerjohn on Sat Feb 16, 2013 8:54 pm
what kind of bulbs are in there ?
bikerjohn
Post by Logi on Sat Feb 16, 2013 9:46 pm
bikerjohn wrote:what kind of bulbs are in there ?
Very small dim ones lol!
Post by HighlyJetted on Sat Feb 16, 2013 10:29 pm
As I've already done a "how to take your dash board apart" for someone else, I'll just copy it in!!
HighlyJetted wrote:Instructions though the medium of art Smile
All bulbs same I think. Just put your fingers on the top of the fascia, push down and pull pretty confidently. The four metal clips hold it on.
Three screws...
Then the connectors hold in via these clip buttons... you have to pull them of gently so you don't damage the foil on the speedo
Then do as its says....
Here are your bulbs, the little black white and blue knobs
cheers
