fitting diesel fan switch
Post by rich the mechanic on Sat Feb 27, 2010 4:04 pm
Hi if you want to use the diesel fan switch to lower the temp and run the fan longer then see the link below
http://richstoys.piczo.com/mods?preview=y&sl=0&st=0&cr=1
This is the only way into this page on my site its a copy of what LP was sent.
Re: fitting diesel fan switch
Post by leopard_pagan on Sun Jul 04, 2010 10:31 am
fitted the switch to my EFI van (petrol) yesterday, works fine.
got a sore neck from soldering the wires while on the ground!
Post by Reid on Fri Dec 16, 2011 7:59 pm
Since removing the radiator fan wiring plugs to check continuity and solder in an overide switch - the fan now starts automatically whenever needed!
Just a push and pull to overcome a little corrosion in a wiring socket!
Incidentally, when I removed the cylinder head to find where the water was disappearing, the head gasket was disintegrated and the water pump gasket the same . . .
Reid
Post by doraimontv on Fri Mar 01, 2013 9:51 pm
Hello.
Can you explain better or make the right link?
Thank you very much.
doraimontv
Post by rich the mechanic on Fri Mar 01, 2013 11:32 pm
Unfortunatly that website has died and I don'y have a copy of the wiring diagram anymore.
Post by melboy on Tue Aug 20, 2013 11:52 am
would i be able to use heated rear window switch which dont work for the manual overide switch for the rad fan?
by the way the switch works ive tested it.
melboy
Post by HighlyJetted on Tue Aug 20, 2013 1:32 pm
Why do you even want a manual over ride switch?
Post by melboy on Tue Aug 20, 2013 8:13 pm
like every hijet owner on here because the hijet coolant system is crap.
p.s, pease of mind.
melboy
Post by rich the mechanic on Tue Aug 20, 2013 8:27 pm
melboy wrote:like every hijet owner on here because the hijet  coolant system is crap.
p.s, pease of mind.
Yes I use one for the fan but I still run it through a relay for my peace of mind, I like a good pudding but rice don't belong in pudding.
Post by ldv.tek on Thu Feb 06, 2014 11:54 pm
Seconds on still running the fan through a relay, lots of amps being drawn for the fan can melt most switches & wiring.
Just for those who dont know thin/crap wire causes electrical resistance, electrical resistance causes the wire to warm up, this in turn increases the electrical resistance and so on until things start to melt if you are lucky or flames start to appear or worse.
ldv.tek
Post by FrontBackSide2Side on Tue May 09, 2017 8:20 pm
Was the original post showing you how to swap the fan switch which is located in the metal coolant pipe for the diesel version?
Or did it show you how to wire in a manual over ride?
Post by Raggy on Tue May 09, 2017 9:03 pm
think it was just a wiring diagram.
Post by Woodie on Wed May 10, 2017 8:22 am
You leave the fan switch in the pipe altogether. No need to touch it.
I fit a rocker switch into the little coin holder on the centre console and put two wires through the rubber grommet that the handbrake lightswitch goes through in the hand brake mounting panel straight to the Fan Relay which is just under the seat. 12" of wire ((behave Logi) straight to the relay and job done.
No need for all this rubbish about extra relays and thicker wires and resistance etc. All you are doing is bridging the operation of the Relay which is a tiny current, not the output to the fan which is a big drawer on current but is obviously accommodated for in the Daihatsu loom.
Post by FrontBackSide2Side on Wed May 10, 2017 5:59 pm
I was hoping that the switch on the diesel models switched the fan on at a lower temperature. That's how I interpreted it with the link not working.
Nevermind!
