Check engine warning light does not come on.
Post by David Devon on Sun Dec 30, 2012 5:20 pm
I own a 1997 Hijet 993 MPV.The check engine warning light (the yellow one) started to flash on for a second when ever I went fast over a bump in the road and it was like the engine had stopped for a fraction of a second.I noticed this for about a week then one morning the engine warning light did not come on when I turned the key in the ignition and still doesn't.All the other warning lights do come on.The engine turns over fine but not even a hint of firing.Any ideas? Thanks,David.
David Devon
Re: Check engine warning light does not come on.
Post by rich the mechanic on Sun Dec 30, 2012 6:09 pm
Hi and welcome I think first port ofr call is to see if there is a fault code you can do this by shorting the two conecters out in the white three point block under the glove box there is a section on fault codes in the manuel see http://www.daihatsuhijet.co.uk/manuals-downloads/ for your model. Any questions just ask.
Post by David Devon on Sun Dec 30, 2012 7:07 pm
Hi,thanks for the suggestion.When I short The terminals Where will the fault code number appear?Thanks,David.
David Devon
Post by rich the mechanic on Sun Dec 30, 2012 7:48 pm
The engine light flashes a sequence which you can then match to the book it maybe worth swapping the bulb with one of the others that you know works just in case.
Post by HighlyJetted on Sun Dec 30, 2012 9:56 pm
If the light doesn't come on at all then the diagnostic mode won't work as there is no power to the EFI/ECU system.
You should know what this fault is Rich Smile A man of your Hijet forum time served!
.......Its the dreaded power terminal on the battery in the boot.
There are two little wires that go on to the live terminal on the battery, there is also a big fat one that feeds the starter motor.
Give the two little ones a wiggle with the key on and I bet the light comes back on. If it doesn't give them a pull and one will probably just fall off.
One of those little wires feeds the EFI/ECU system, when it brakes you lose the engine warning light entirely and the van will never start as the ECU has no power.
Bet it fixes it! We've had about 5 people turn up here like this plus it happen to my first Hijet, I drove over a hump back bridge and it cut out - at night too.
If it doesn't I can give you all the info you need to get it working, just post back cheers
Post by rich the mechanic on Sun Dec 30, 2012 10:24 pm
HighlyJetted wrote:If the light doesn't come on at all then the diagnostic mode won't work as there is no power to the EFI/ECU system.
I forgot about that I haven't plucked up the courage to even look at the one on ours incase it decides to fall apart.
Post by HighlyJetted on Mon Dec 31, 2012 12:24 am
Can't wait to hear back from David,
Lets see if he's just another notch on the "dreaded battery wire of fury" bed post Laughing
Hope so as its a nice easy fix!
Success!
Post by David Devon on Mon Dec 31, 2012 1:58 pm
It was the wire from the +terminal. Things are a lot tidier down there now. Starts beautifully. Many thanks, David.
David Devon
Post by rich the mechanic on Mon Dec 31, 2012 2:17 pm
Post by HighlyJetted on Mon Dec 31, 2012 3:33 pm
Wicked!
Now that's the power of the hijet owners forum
Post by Logi on Mon Dec 31, 2012 3:49 pm
HJ, the god of Hijets Twisted Evil
Post by HighlyJetted on Mon Dec 31, 2012 4:51 pm
WTF can you say to that?
That's like saying "the god of rotten cheap shit" - cheers.
Post by Logi on Mon Dec 31, 2012 5:20 pm
HighlyJetted wrote:WTF can you say to that?
Better to rule in hell than serve in heaven Razz
