Differential leak!
Differential leak!
Post by El_Ventu on Fri Jan 04, 2013 5:49 pm
My rear differential starts to leak a huge amount of oil from the transmission shaft, yesterday.
I hope it is only the oil seal, that I bought today...
News coming in next days Very Happy
El_Ventu
Re: Differential leak!
Post by rich the mechanic on Fri Jan 04, 2013 10:13 pm
the only other thing it can be is if shaft is damaged by grit getting under the seal if it is that then the new seal will help but may not cure.
Post by HighlyJetted on Fri Jan 04, 2013 11:23 pm
Bad luck mate. Nice easy job to get to it I think, not that I've done one before, but its easy to get the drive shaft off then I think take the flange off the input shaft
Post by El_Ventu on Mon Jan 07, 2013 6:51 pm
Seal changed!
Not a bad job, the main difficulty was to lift the Porter with the "arm" lifter...
4 bolts to loose the shaft, and a bolt to release the "cup" that enters in the differential.
A smart idea, in the inside there's the spline, and on the outside works the seal.
Then if the seal damage it's surface, you can easily change it, a simple and lesscostly work than change or repair the shaft.
Now I hope the leak was fixed Razz
El_Ventu
Post by HighlyJetted on Mon Jan 07, 2013 7:52 pm
Only time will tell!
You'll be right.
