Floppy Mirrors
Floppy Mirrors
Post by Marcfe on Sun Jan 13, 2013 10:51 pm
Anyone got any tips on how to get my mirrors to stop flopping around?
The screw bit is broken Sad
Thinking maybe a glue of some sort?
Marcfe
Re: Floppy Mirrors
Post by HighlyJetted on Sun Jan 13, 2013 11:03 pm
Have been known to grip fill/glue my own ball adjustment up in the past. Laughing
Re: Floppy Mirrors
Post by rich the mechanic on Mon Jan 14, 2013 9:33 pm
I have yet to try it but as I have one loose mirror it will be soon but I think a small wedge pushed up the casing and maybe a securing cable tie should do it I have had some self tappers wedged up the slot which worked for a while although I think they have fallen out I haven't looked if it works I will post up sizes unless someone else beats me to it.
self tapping screws
Post by pww on Mon Jan 21, 2013 9:12 pm
Had same problem of plastic "gripper" broken. Undo the bottom nut and withdraw the shaft (OOh Err missus) try to keep the mirror roughly in the same position on the shaft while turning upside down, srew one or two self-tapping screws between the plastic retaining clip and the ball. With any luck the screws bite into both enough to hold the mirror in place - unless you slam the doors hard! You should still be able to move the mirrors to adjust. Worth a try
Paul
pww
Re: Floppy Mirrors
Post by Marcfe on Mon Jan 21, 2013 9:34 pm
I'm going to try and use a small hi speed drill bit and then tap a thread into the ball and then bolt it
Marcfe
mirrors
Post by hijetx2 on Tue Jan 22, 2013 9:58 am
I remove the mirror totally leaving the metal ball - clean both parts - the metal ball then plastic cup it sits in.
then go the pound shop and get a tube of apoxxy resin, mix it up and stick it in the right place. - usually lasts untill someone knocks it out of place - which is highly annoying loool/....
hijetx2
http://www.southportforsale.co.uk/index.php
Re: Floppy Mirrors
Post by d1noh on Tue Jan 22, 2013 9:04 pm
What about the 2009 or newer mirrors
bet they mount the same, under 20 euros
[url]SPECCHIO RETROVISORE LATO SINISTRO PIAGGIO PORTER DAL 2009 | eBay [/url]
Re: Floppy Mirrors
