Am I starving?
Am I starving?
Post by PFM on Wed Feb 20, 2013 6:15 pm
Talking of oil starvation (well HJ was just now), my 1995 993 which the servicing fairies ignored for 6 years (yes, I know Embarassed ) began sounding a bit 'tinny up top'. I hoped the oil and filter change would have improved things, but sadly it seems not. Anyone know if there's a gauze-covered pick-up pipe in the sump of these or is the oil carried up in some other way? I can't see anything in the 3cyl EFI manual. Or, is there anything else it could be? Doesn't sound like tappet adjustment to me.
Re: Am I starving?
Post by HighlyJetted on Wed Feb 20, 2013 6:48 pm
Yeah it'll have a pickup pipe with a gauze - every engine i've had apart to date has a setup like this.
Because otherwise the oil pump could pump up really big bits of crap which would destroy the pumps internals. The oil filter itself is always after the pump as it works under pressure.
And more than likely it'll want the valve clearances doing.
Re: Am I starving?
Post by PFM on Wed Feb 20, 2013 8:24 pm
Thanks, M8. I wonder how long I'll be safe leaving this 15/40 in as a 'flush' - don't want to drop the sump till it warms up a bit. Any idea if there's a re-useable gasket between sump and block or if I'll need a new one?
Re: Am I starving?
Post by rich the mechanic on Wed Feb 20, 2013 9:13 pm
Do the valve clearence and remember to do it hot our 993cc sounds tinny when it needs doing I think being a triple it does sound different and while you have the rocker/cam cover off blip the starter but don't let it start, the two bolt holes that the cover is held down with across the top the rear one is the oil way and you should get a slurge of oil out if the top with the bolt out I found this out when being lazy doing the clearences and not turning the crank over by hand.
Re: Am I starving?
Post by HighlyJetted on Wed Feb 20, 2013 9:29 pm
There's always a bit of instant gasket! But remember, less is more.
Re: Am I starving?
