993 efi mpv cooling system pipe.
Post by David Devon on Wed Feb 20, 2013 9:55 pm
I am after a metal cooling pipe which is about 30 cms long 2.5 cms dia. with the filling port coming out of the top towards the front of the pipe with a radiator cap on it.It lives directly under the passenger seat.Mine is corroded where the filler bit is joined onto the horizontal pipe.Any out there?
David Devon
Re: 993 efi mpv cooling system pipe.
Post by rich the mechanic on Wed Feb 20, 2013 9:56 pm
got a pic they usually rust a bit but can be cleaned up and re painted.
Post by HighlyJetted on Wed Feb 20, 2013 10:20 pm
David, read this post:-
http://hijet.findtalk.biz/t1018-fitting-new-radiator-and-expanion-pipe-tube-pictures
That guy walked into some kind of radiator place, and they made him a new one up from copper/brass etc.
You can order radiator cap plug hole assemblies on the internet, and you can buy pipe easily. All you need to do is find a nice guy who will solder/braze it together.
When you go looking for those pipes, most of them are on there way to rotten nowadays. You may find an OK one, then a year or two later its causing you problems. So maybe save yourself the heart ache and get one made up that will last you forever being brass or copper.
Post by David Devon on Thu Feb 21, 2013 6:47 am
rich the mechanic wrote:got a pic they usually rust a bit but can be cleaned up and re painted.
This one leaks a bit and previous owner has tried to repair it with what looks like araldite.I will take the pipe off and have a good look.Thanks,David.
David Devon
Post by David Devon on Thu Feb 21, 2013 6:57 am
HighlyJetted wrote:David, read this post:-
Im going to take the pipe off and have a good look.I like the idea of one that won't corrode.Thanks for the advice and the link,David.
David Devon
