Problem with table lamps.
Post by doraimontv on Fri Mar 01, 2013 9:34 pm
Hello.
I have two red lights lit all the time.
I removed and tested the alternator diode rectifier winding and brushes. Everything seems right.
No battery provides 13.8 volts.
With battery provides 13.1 volt battery.
Battery cables and terminals, seem correct.
What else I can look?
I put a video.
h t t p : / / youtu.be/266ZvtRf3hc
Greetings from Spain.
Ahhhh, is Piaggio Porter, 1200 diesel. 97.
doraimontv
Re: Problem with table lamps.
Post by xxemaphorr on Sat Mar 02, 2013 9:58 am
first time i've ever heard a diesel one. Dont they run quiet! Rolling Eyes
Do flash codes tell you anything?
xxemaphorr
Post by doraimontv on Sat Mar 02, 2013 10:16 am
thank you very much for quick response.
How do I look flashing code?
the van is 97.
a greeting.
doraimontv
Post by Logi on Sat Mar 02, 2013 10:35 am
One is the handbrake warning, i'd guess maybe a short somewhere behind the dash?(i presume the handbrake light doesnt go out when you release it?)
Post by doraimontv on Sat Mar 02, 2013 2:37 pm
Hello.
No flash out codes. How do you do?
I put another video.
http: / / youtu.be/ji4kqY1_o_gç
The handbrake is fine.
Any idea?
Thank you very much.
doraimontv
Post by Logi on Sat Mar 02, 2013 3:03 pm
Apologies, it's not the handbrake one Embarassed
Post by doraimontv on Sat Mar 02, 2013 3:19 pm
Hehehe, do not worry
Any idea I can look now?
doraimontv
Post by doraimontv on Mon Mar 04, 2013 9:44 pm
No one can guide me?
doraimontv
