LPG High Idle and Petrol 'Hunting' Idle on 1.3 EFI 16v HiJet
Post by HiJetSi on Mon Mar 11, 2013 4:20 pm
Hello All!
I have recently purchased a Hijet 1.3 EFI 16v Dual Fuel HiJet.
I already have a problem though:
- The idle is very high when running on LPG (about 2000rpm) and stays like this when warm.
- The idle tends to 'hunt' when on Petrol - up, down, up, down and also stays like this when warm.
Tonight I am going to:
- Check Coolant Level
- Start on fuel firstly rather than LPG and see how it idles
- Add a fuel additive/cleaner
Can anyone give me some advice on what to try next if the above does not solve the issue?!!
Cheers!
Simon
HiJetSi
Re: LPG High Idle and Petrol 'Hunting' Idle on 1.3 EFI 16v HiJet
Post by HighlyJetted on Mon Mar 11, 2013 5:23 pm
Yes common fault, caused by one or a number of things. Most commonly caused by:-
Idle speed control valve on the back of the inlet manifold/throttle body is not getting coolant though it.
Which is most commonly caused by it having problems with the coolant system and over heating.
