alloys on ebay
alloys on ebay
Post by HIJET1300GT on Tue Mar 19, 2013 8:03 pm
says they are 110 pcd ?????
http://www.ebay.co.uk/itm/181104235027?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
not my thing but someone may love them! Very Happy
HIJET1300GT
Re: alloys on ebay
Post by HighlyJetted on Wed Mar 20, 2013 3:45 pm
Not anymore.... I got him to measure again carefully Wink
Re: alloys on ebay
Post by HIJET1300GT on Wed Mar 20, 2013 4:21 pm
108 by any chance?????? What a suprise !
HIJET1300GT
Re: alloys on ebay
Post by HIJET1300GT on Wed Mar 20, 2013 9:42 pm
HIJET1300GT
Re: alloys on ebay
Post by HighlyJetted on Thu Mar 21, 2013 11:27 am
I'm not sure where you would actually re-drill the front hubs.
There's not alot of free space on them.
Re: alloys on ebay
Post by HIJET1300GT on Thu Mar 21, 2013 12:44 pm
I'm using the original stud hole space and just moving them inboard . The dead space will be welded up then re drilled at the new pcd . Ill put the pics up when I'm done, I've only got as far as stud removal and turning down the centre bore.
HIJET1300GT
Re: alloys on ebay
Post by Logi on Thu Mar 21, 2013 3:01 pm
That could be costly unless you or a mate are doing the work? £350 for a new set of 14's doesnt seem too bad I re kon?
Re: alloys on ebay
Post by HIJET1300GT on Thu Mar 21, 2013 3:21 pm
Me and a mate are on the case , It shouldn't cost me a penny but he dose like a beer and I can't have the chap Run dry!
HIJET1300GT
Re: alloys on ebay
Post by HighlyJetted on Thu Mar 21, 2013 3:37 pm
I'd be tempted to weld them up first, then turn them because then you can turn back your welds and sort out any distortion at the same time.
Make sure the welder is pretty serious, you want proper penetration in the welds, which means its going to get bloody hot.
Re: alloys on ebay
Post by leopard_pagan on Thu Mar 21, 2013 6:14 pm
Re: alloys on ebay
Post by HIJET1300GT on Thu Mar 21, 2013 7:11 pm
The flange mating surfaces will be refaced after the weldings been done . As for the really deep hot penetration Razz ill make sure the welder puts it all in !
HIJET1300GT
Re: alloys on ebay
Post by rich the mechanic on Mon Mar 25, 2013 10:01 pm
Surely it would be easier to fit some offset wheel studs no welding needed no need to set up true in a lathe and several hours quicker to fit just may need to drop down to a 10mm stud instead of 12 depending on how big the press fit bit is and then you can convert front and back to match.
Re: alloys on ebay
Post by HIJET1300GT on Mon Mar 25, 2013 10:18 pm
Offset wheel studs ? They sound like they cost money!
HIJET1300GT
Re: alloys on ebay
Post by rich the mechanic on Mon Mar 25, 2013 10:28 pm
http://www.performancealloys.com/wheel-studs.aspx this is the first place I found and I forgot to add that you could do with longer studs for alloys over steels so all done in one hit on this site all four wheels would cost £56 and I recon that welding and machining would take about 2 hours per wheel and you should replace the studs rather than reuse them, and working on a tenner an hour would be £80 if it all goes to plan
Re: alloys on ebay
