FREE white LED tape
FREE white LED tape
Post by HIJET1300GT on Wed Mar 20, 2013 5:01 pm
ive got three 1meter lengths of this bright white (4000K ) led tape .
use it in one lenght as a big interior light or it can be cut and used in shorter sections ( makes an excellent glovebox light Very Happy )
its sticky back and just solder + - 12volts on and your away!
first 3 people to inbox me get some cheers
HIJET1300GT
Re: FREE white LED tape
Post by rich the mechanic on Tue Apr 16, 2013 9:35 pm
Stage one a little test to make sure I don't go all number 5 with water and all is good so at least need to make three more of these up like this can you guess what for?
Post by HIJET1300GT on Tue Apr 16, 2013 11:07 pm
Day time running lights??
HIJET1300GT
Post by elfin girl on Tue Apr 16, 2013 11:11 pm
these are cool, cant wait to use mine, if nobody wants them id be happy to take the rest, but that would just be greedy!
oh, and youll know when it arrives cos theres a little doodle of a hijet on the envelope Very Happy
Post by rich the mechanic on Wed Apr 17, 2013 9:02 pm
I was misleading a little because two will be used on the jet well because I can but the other two are going on my car to replace the conventional led setup I fitted years ago that Mr MOT man struggles to see.
Post by HighlyJetted on Wed Apr 17, 2013 9:12 pm
I wanna see the doodle of the hijet on the envelope.
Almost makes me want to ask for some, but I have no use for them!
Post up the doodle Smile
Post by rich the mechanic on Wed Apr 17, 2013 10:09 pm
Post by HighlyJetted on Wed Apr 17, 2013 10:24 pm
How cool!
Post by rich the mechanic on Sun May 19, 2013 6:21 pm
Had a chance today to play
and
now to wait till it gets dark to see how well they work and now you know why I needed to make them water resistant.
Post by rich the mechanic on Sun May 19, 2013 9:19 pm
and now at dusk
Post by HighlyJetted on Sun May 19, 2013 9:39 pm
Bet your clocks will light up the whole cockpit pretty much!
Post by gltease on Mon May 20, 2013 10:59 pm
used this led tape on the inside of van sticks well and a brilliant light, connects to existing light using festoon adapter.
gltease
Post by rich the mechanic on Fri May 24, 2013 11:13 pm
HighlyJetted wrote:Bet your clocks will light up the whole cockpit pretty much!
Yeah it's great when there is dusk or daylight but too bright when it is dark. Have you got any dash dimmer switches that look a bit like jet switches or at least will fit in the dash?
Post by rich the mechanic on Fri May 24, 2013 11:14 pm
Gltease I bet you can see what your looking for now.
Post by Manuel_nl on Sat May 25, 2013 2:37 pm
It's not possible to dimm LEDs as regular bulbs we are used to.. You will need to ad some extra electronics to do it properly.
Manuel_nl
Post by rich the mechanic on Mon May 27, 2013 7:11 pm
Manuel_nl wrote:It's not possible to dimm LEDs as regular bulbs we are used to.. You will need to ad some extra electronics to do it properly.
So long as you only want a small amount of adjustment they can be dimmed I have had LED's running at half voltage and they work ok but three quarters voltage works fine.
Post by HighlyJetted on Mon May 27, 2013 9:56 pm
I'd fully agree, LED brightness does depend on voltage. So a couple of resistors or even just a potentiometer would offer you variable light levels.
Post by rich the mechanic on Mon May 27, 2013 10:09 pm
Well HJ have you any goodies stashed?
Post by HighlyJetted on Wed May 29, 2013 1:23 am
I need to know either:-
The part number ID info so I can read the data sheet for the LED's
or
How many watts per meter they are rated at etc (and how long your sections are)
Then I can make you a little board with some components in place and some input / output leads so you can just connect up and go.
Post by rich the mechanic on Wed May 29, 2013 9:36 pm
No worries I can make up a trick bit I was thinking about a push button to dim and when the lights go off it resets so it's full power again when they go back on as i have a habit of leaving the lights on when I have had them on in the day because I can't see the lights are on.
Post by HighlyJetted on Wed May 29, 2013 9:40 pm
I'm sure if you run them on 6v they will be alot less sharp at night.
To make 6v from 12v you need to setup a "potential divider"
http://www.youtube.com/watch?v=ZkC6SVrW2Wc
Basically just two resistors, to make 6v from 12v, the resistors need to be the same value.
You just need to make sure the resistors can handle the "wattage" that the LEDs will consume.
Post by rich the mechanic on Wed May 29, 2013 9:54 pm
I have build a few LED brake lights and the dual light I normally handle by resisting the LED's down to around 9v assuming they are 12v this still give a good light, (6v is on but no useable light) then bypass that resistor to get full power. I know that it isn't resisting voltage but it's the easiest way to explain as I have to look at the equation and get the calculator out.
Post by rich the mechanic on Wed May 29, 2013 10:26 pm
not the best display the shadow says more than the light itself.
Post by Willst0ne on Sun Jun 23, 2013 9:04 pm
Hi,
I'm interested in some. Have you any left? If not where did you find it from?
Cheers,
Will
Willst0ne
Post by lestersteve on Sat Aug 10, 2013 11:04 am
love abit of that that:P Very Happy Very Happy Very Happy  cheers:
lestersteve
