plugs question and valve clearances
Post by streetboy on Tue Mar 26, 2013 7:54 pm
Hi all, yes I should troll through the search Embarassed but in a proper rush tonight and need some info asap for tomoz.
993cc plug gaps, and valve clearances please.
streetboy
Re: plugs question and valve clearances
Post by HighlyJetted on Tue Mar 26, 2013 11:56 pm
Should you trust an answer you get off someone hear say?
Check the engine manual!
http://www.daihatsuhijet.co.uk/pdf_manuals/Workshop%20Manual%20-%20Daihatsu%203%20cyl%20993cc%20EFI.pdf
Spark Plugs page 77, gaps and spec.
But because i'm too helpful here is a chop out of the manual:-
Post by streetboy on Wed Mar 27, 2013 6:05 am
Top man, very good of you sir Wink
just those to do today and the timing belt, oil and filters if I get time, and the little bus is sorted. Very Happy
streetboy
Post by streetboy on Wed Mar 27, 2013 7:00 pm
change of plan and decided to change the thermostat as its always had a crap heater and I have had to sling a cardboard muff over the rad to get some heat. Laughing
I now have one more thermostat than I started with! no wonder it was rubbish Rolling Eyes
Early signs are ok, temp gauge sitting halfway now and not affected by driving at 40-50mph for any length of time which would drag the already reluctant needle down to just about nowt.
Test will be a bit of traffic and see if she gets to warm.
streetboy
Post by PFM on Wed Mar 27, 2013 7:18 pm
(Chuckling, imagining HJ tearing his hair out)
My '95 993 heater has been useless this winter - reckon the matrix core is clugged up, am tempted to Fernox it when the weather gets warmer - but then I'll probably forget about it until is cold again and then won't want to do it!
Post by streetboy on Wed Mar 27, 2013 8:15 pm
Laughing I kept promising myself I would do it last winter and never did. In the end it took 10 mins.
Madness Laughing
streetboy
Post by HighlyJetted on Wed Mar 27, 2013 8:38 pm
PFM wrote:(Chuckling, imagining HJ tearing his hair out)
Have you been watching me today working on this Corsa today?
Well done with the thermostat, you have to ask yourself why is had no thermostat in it Wink
Post by streetboy on Wed Mar 27, 2013 9:45 pm
Did cross my mind. Mind you when I brought it it had a leaking rad. I kept that going for over a year thanks to chemical metal! Laughing then bit the bullet and fitted a replacement when it fell to bits. the things we do eh?
Took it for a run and so far all seems good, so fingers crossed.
like I said, its been long overdue I shelled out a few bob on her Laughing
Should have the rest nailed by Saturday then make the 4 hour trek down to Devon next Thursday.
streetboy
Post by streetboy on Mon Apr 01, 2013 7:06 pm
Well all done, must say the timing belt was a nice simple job in the end Smile
Poor little thing don't know whats hit it!! little sowing machine Wink
streetboy
