wiring loom and central locking
Post by rich the mechanic on Sun Mar 28, 2010 6:36 pm
I found out today why my drivers door isnt connected in to the central locking, I had noticed that the wiring for the passenger door gets pulled quite sharply around the inner edge of the wing and now I have found the two ends of the drivers side that would only be cut off cleaner if it had been done with side cutters. I think I may have to take the wing off to get enough room to solder in a drop link will have to do the passenger side before that keels over.
Re: wiring loom and central locking
Post by leopard_pagan on Sun Mar 28, 2010 8:49 pm
if you can, use some heat shrink to protect the joint.
Post by rich the mechanic on Sun Mar 28, 2010 9:50 pm
Oh yes I've got some in my soldering iron box but will have to nip into Maplins over other side of town to get some bigger diameter to cover the 5 wires, I only tape inside connections in a car coz I'm lazy outside and bike are always heat shrinked although I've never tried the stuff with the glue in for the really water tight joint.
Post by leopard_pagan on Mon Mar 29, 2010 6:40 am
we call it glue line. its brilliant, but its a use once job.. so dont put it in the wrong place.
ideally you need a heat gun to shrink it down. a hair dryer (on high) or paint stripper on medium setting will do fine.
Post by rich the mechanic on Mon Mar 29, 2010 9:01 pm
Clare is a crafter I nick her heat gun (its medium high heat with a soft blow) if I cant get to it with the tip of my 100 watt soldering iron or a lighter.
Post by leopard_pagan on Tue Mar 30, 2010 6:49 am
lol.. its when you miss and melt the wire i hate!
Post by rich the mechanic on Tue Mar 30, 2010 6:53 am
Me!!!!! I would never do a silly thing like that I'm a Professional mechanic lol! we only work to the highest standard lol! but I can put the fire out real quick.
