Getting one Friday... but....
Post by leopard_pagan on Wed Mar 27, 2013 9:23 pm
£270
1.3 EFI MPV, blue, bodywork looks ok
unknown mileage, no keys.. HPIed the reg in the photo & will be checking if the VIN matches.
advertised as a non-runner* so expect a few posts in workshop section &if its a total lemon.. i'll break & sell off to get money back.
*Current owner bought to export to Nigeria but has no idea whats wrong with it..
btw.. is it just me or anyone notice the MPV 1.3s kinda scarce as i am guessing most have been exported out the country!
Re: Getting one Friday... but....
Post by Logi on Wed Mar 27, 2013 9:30 pm
cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers
Post by leopard_pagan on Wed Mar 27, 2013 9:51 pm
lol.. wont celebrate just yet... wait n see just how bad this thing "wont run"...
Post by waz on Wed Mar 27, 2013 9:52 pm
Logi wrote: cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers cheers
That's made you happy then Logi Very Happy Very Happy
Post by leopard_pagan on Fri Mar 29, 2013 6:39 am
And the fun begins...
Fuel can with fuel... Check
Coat hanger & box strapping to break in to van... Check
Car & Trailer/tie downs... Check
Cash... Yup
Entertainment of the seller desperate to sell = me attempting to bargain a few more quid off....
Not got ant expectations, were going to 1) try & get in to the van so I can check the VIN/HPI & try to start it..
Post by HighlyJetted on Fri Mar 29, 2013 10:44 am
They are unbelievably easy to get into without keys!
Take the water seal strip off the door, then put a little fold in the end of a straightened out coat hanger so its hook like and pull the mechanism.
If you need a lock set I have a complete van lock set with 1 key.
Remove the cowling off the steering wheel, and take the black switch back off the ignition and see if it runs.
You'll need a nice little chisel to undo the sheer bolts off the steering lock mechanism. Chisel a little noggin on the side of the bolt head, then use it to chase them round to undo them.
Post by Logi on Fri Mar 29, 2013 11:11 am
HighlyJetted wrote:They are unbelievably easy to get into without keys!
You're surprisingly well schooled on breaking into cars........... Razz
Post by HighlyJetted on Fri Mar 29, 2013 11:40 am
Factory Engine immobilizers built into the ECU is where is gets impossible.
With the honda civics I have an ECU I can plug in without any immobilizer Smile
Post by PFM on Fri Mar 29, 2013 12:39 pm
Good luck LP - hope you've bagged a little gem (but lettuce see.....)
Post by leopard_pagan on Mon Apr 01, 2013 3:50 pm
lettuce? lol...
the original van i went to see is re-advertised & hes NOT stated that the engine is seized despite us showing him it was..
