Engine Warning light!
Post by pasiro on Fri Mar 29, 2013 4:55 pm
The warning light for the electronic control system, has started coming on for the first time since I got the van, what exactly would be the problem, I really don't know what this has to with but I'm hoping it's easily and CHEAPLY fixed?
I also noticed today when I started her that she was idling about twice as quick as normal?
She's also taking a lot longer to get up to temperature?
Once running she seems to go fine however she did overheat about a month ago, not been far enough since to see if it still happens
pasiro
http://chorc.net
Re: Engine Warning light!
Post by HighlyJetted on Fri Mar 29, 2013 5:30 pm
The engine warning light coming on means its registered an error code.
You can read the error codes easily if you have a pre 2002 van for nothing.
After 2002 you need a scanner of some form.
Read this page on my site for the guide to how to get the codes, and for a full list of their meanings!
