tow bar wiring.. fun!
Post by leopard_pagan on Mon Apr 22, 2013 5:59 pm
Right, tow bar fitted yesterday; easy enough job for 2 people to do.
had a good look at the electrics today (fit tomorrow) & have decided to strip the outer off right back almost to the socket (3-4" away) split (T) the wiring going Left & right, re-wrap each direction, thru the gromit in to side & up to rear lights & wire in there.
i dont want to cut wires under the van for 2 reasons.. 1) wires exposed to corrosion once cut.. even if you solder/heat shrink. 2) i really do not fancy another face full of dirt from under the van..!
doing things this way does mean the indicator buzzer will become unusable as thats wiring is only 4-6" long! TBH i ALWAYS check all lights are working before i pull any trailers!
Re: tow bar wiring.. fun!
Post by Logi on Mon Apr 22, 2013 6:24 pm
I just ran a wire over the top to the other indicator?
Post by leopard_pagan on Mon Apr 22, 2013 7:17 pm
hmmmm.... i'll have a look tomoz
Post by Logi on Mon Apr 22, 2013 7:56 pm
It's a bit of an arse to get the wire through, don't use my name when swearing at it Wink
Post by HighlyJetted on Mon Apr 22, 2013 8:23 pm
I went in both sides at the bottom and hooked the wiring in at the back of the light clusters.
Post by Logi on Mon Apr 22, 2013 8:25 pm
HighlyJetted wrote:I went in both sides at the bottom .
Must.... Resist............ Evil or Very Mad
Post by rich the mechanic on Mon Apr 22, 2013 9:48 pm
The sounder is a legal requirement you need that or an light indicator on the dash so if you have a tug it could get added on, saying that I ran for years without one and only fitted a sounder beacuse I was given one and I had some other wiring to do.
Post by HighlyJetted on Mon Apr 22, 2013 10:23 pm
I've never bothered with them, beeping away doing your head in!
Post by leopard_pagan on Tue Apr 30, 2013 11:08 pm
All done & tested Smile
