Replacing the steering wheel
Post by bushwhacker on Tue May 07, 2013 3:27 pm
Having found a boss which will probably fit, although the indicator self cancelling may not work, I now need to remove the original wheel.
The question is, how do I get the horn push off? Do I carefully lever it out with a screwdriver or similar or is it screwed down somehow? (The workshop manual is no help as it simply shows a numbered exploded diagram and says 'remove in numbered order'; no mention of methods or damage limitation).
Re: Replacing the steering wheel
Post by waz on Tue May 07, 2013 4:35 pm
As I remember it just pulls of, held on by 4 spring type things
Post by HighlyJetted on Tue May 07, 2013 6:03 pm
Put your fingers under the top and pull!
Interested to know what this boss kit is off or the part number
Post by bushwhacker on Tue May 07, 2013 6:27 pm
HighlyJetted wrote:Put your fingers under the top and pull!
Mountney Traditional boss kit MB099 for a Daihatsu Charade 83-87. Another manufacturer gives the same part number for that and the Japanese version of the Hijet that supposedly matches the European version. Therefore it should fit.
However, the self cancelling doesn't look quite the same but we will see.
The only other problem is that the part has been discontinued although they still have stock at the moment.
Post by HighlyJetted on Tue May 07, 2013 10:15 pm
Sounds promising, only a 5 minute job to fit it, fingers crossed and good luck with getting the original wheel off with some force.
Post by Logi on Wed May 08, 2013 12:21 pm
Remember to leave the nut on loosely whilst pulling against the wheel esp if you have someone hitting the column with a soft hammer.
Steering wheels are nose seeking missiles when released from the confines of the column..... Wink
Post by chinfuk on Wed May 28, 2014 8:25 pm
Logi wrote:Remember to leave the nut on loosely whilst pulling against the wheel esp if you have someone hitting the column with a soft hammer.
Haha
Thanks for the tip :-)
chinfuk
