Non running
Non running
Post by tat1959 on Thu May 09, 2013 10:01 am
HI
Can anyone give me any ideas. I parked my 1300 Hijet up for about an hour and when I came back to it it would not start not even any attempt to start, engine turns over fine and there is fuel in it. I will be having a look at it at weekend and was hoping that someone may have any ideas if there is a common complaint like this.
Stuart
tat1959
Re: Non running
Post by HighlyJetted on Thu May 09, 2013 5:22 pm
Does the engine warning light come on when you turn the key?
If you get no light, the little wires to the battery live terminal have broken....
Re: Non running
Post by tat1959 on Fri May 10, 2013 9:30 pm
Further investigation shows that the warning light does come on when you turn the key. but the fuel pump does not work unless you give the tank a hit which un sticks the fuel pump, so I need a new pump any ideas where is the best place to get one.
Stuart
tat1959
Re: Non running
Post by HighlyJetted on Fri May 10, 2013 11:03 pm
I think they are a standard pump, look like a silver tube can thing . You take the top off the tank, and pull it out and its just bolted to a bracket.
Loads of cars use the same pump type so I would have though any motor factors would sort you out.
Re: Non running
