Hijet LPG questions
Hijet LPG questions
Post by Willst0ne on Sun May 12, 2013 3:06 pm
Hello,
I've bought this vehicle and am looking for help with a number of problems. I should probably list them all separately but I thought I'd try this first....
1. What is normal engine running temperature? The needle sits about two thirds whilst on most journeys. Is this hot, normal or am I just being paranoid it's going to over heat!!!??
2. The cab heaters do not blow warm air. HOWEVER, the window heaters and floor/footwell heaters do? Is this some sort of air block or just some ducting come loose?
3. It shows on the v5 as a light goods vehicle - surely it is a petrol car? Anyone had experience of changing this on their v5?
A thousand thank you's in advance.....
Will Stone
Willst0ne
Re: Hijet LPG questions
Post by Logi on Sun May 12, 2013 3:47 pm
Hello, welcome to the site. Smile
1 Hijets do run a wee bitty warm, plenty here for you to read about bleeding, thermostats, caps etc.
2 Hijets all blow cold through the vents, nowt to worry about as long as floor & screen are hot.
3 Again, plenty to read here on that subject.
Post by Willst0ne on Sun May 12, 2013 7:29 pm
Thanks Logi. I'm sure to be back for more help as such great resource you have here. W
Willst0ne
