Sliding door bearings
Post by leopard_pagan on Tue May 14, 2013 6:55 am
Any tips on doing the middle ones?
Anyone know if the top bearing is the same as the middle ones?
Both sides have been "gritty" despite the amount of grease used!
Re: Sliding door bearings
Post by HighlyJetted on Tue May 14, 2013 9:51 am
Yeah, don't get those kits on ebay!
You can buy a tube of 10 bearings for a couple of quid.
I've not done the top ones yet, but need to on the drivers side on my van.
Post by leopard_pagan on Tue May 14, 2013 6:09 pm
ahhhh... too late.. BUT once i get one off i can grab the Part number/dimensions to get others!
http://www.bearingstation.co.uk/Products/Bearings/Miniature_Bearing/Miniature_Bearing/6882RS
Post by PFM on Tue May 14, 2013 6:24 pm
I'm sure I posted my method for doing this but can't find it. IIRC you remove the plastic cap at the rear of the slide at the back of the van (1 screw), slide the door fully open and ease the hinged part out of the slide. The bearing is held on by a torx-headed bolt. May help to remove the stop on the lower runner. I think top, middly and lower bearings are the same and I did post the bearing number - anyone help find my post?
I used to remove the hinge from the door, but it's a bugger to get it aligned correctly afterwards.
Post by HighlyJetted on Tue May 14, 2013 7:14 pm
leopard_pagan wrote:ahhhh... too late.. BUT once i get one off i can grab the Part number/dimensions to get others!
8 X 16 X 5mm by dodgy ruller ( Wink rich) type measurements
Post by rich the mechanic on Tue May 14, 2013 7:48 pm
do it properly and use a micrometer for proper measuring Smile
Post by HighlyJetted on Wed May 15, 2013 1:40 am
That means going to the garage!
My digital verniers in my office draw need new batteries.
But my Wright and Moor stuff all has recharger packs and mains adapters thank god.
Post by leopard_pagan on Thu May 16, 2013 9:57 pm
i got the same with my dodgy ruler too.. my micrometer is in the shed.
Post by kentgpz11 on Thu May 16, 2013 10:16 pm
kentgpz11
Post by Guest on Fri May 17, 2013 6:20 am
Thanks guys for all the above discussions. Its not that after my massive Workshop and Garage tidy up I didnt still know where mine were---- I am still tucked up in my nice warm bed and cant be bothered to go and measure the ones I have on a shelf in the garage.
So cheers chaps I'm off back to Noddy land for another hour. Sleep
Sorry what was that ?? What am I doing up now then ? Age related connection between a small glass of cider and the smallest room in the house.
Sad innit this getting older business ???? Not that that many of you lucky YOUNG beggars out there would know.
Post by Manuel_nl on Fri May 17, 2013 9:20 am
My method is a bid different. I remove the plasic cap and the rear light. Remove the bolts from the sliding rail and while holding the door slide the rails from the door. Use a big woodblock to support the door. You can now change your bearings. Its also a nice moment to check for rust at the body beneath the the sliding rails
Manuel_nl
Post by HighlyJetted on Fri May 17, 2013 9:30 pm
I pulled my finger out and fixed my driver side sliding door, and while I did it I took some pictures and did a write up....
http://www.daihatsuhijet.co.uk/repair-hijet-sliding-doors-rough-sticking-grinding-bearings-dropped/
Mine slides so effortlessly now, you just touch it and it slides nicely.
If they have been grinding on the stainless rail for a while then take some abrasives to it and make it smooth again. Mine was a bit chewed up in one place and after a bit of sanding they ran nice.
Post by leopard_pagan on Sat May 18, 2013 9:54 am
Very Happy cheers..
