Few questions
Few questions
Post by fleurjon on Tue May 14, 2013 8:56 pm
Hello
Could anybody tell me what the (!) sign means on my instrument panel? Keeps coming on and then going off. Also are hijets prone to not starting in the damp? Just had fun bump starting it down the hill but will start fine now, could this be dodgy spark plugs?
Cheers
fleurjon
Re: Few questions
Post by Manuel_nl on Tue May 14, 2013 9:46 pm
In my opinion Hijets have a clean start in all circumstances.
Manuel_nl
Re: Few questions
Post by rich the mechanic on Tue May 14, 2013 9:52 pm
The fluid level is low and needs topping up but check for leaks ours did this last year and the LSPV had developed a minor leak that escalated fairly quickly to a very unsafe braking system but it could also mean that the pads and shoes are getting low and need to be replaced this will bring the level back up but a fluid change never goes amiss if you don't know when it was done last.
Re: Few questions
Post by fleurjon on Wed May 15, 2013 5:33 pm
Thanks very much, topped up the fluid and all seems in working order. Thanks for the quick response, really appreciate it!
fleurjon
Re: Few questions
