New Aerial
New Aerial
Post by craig2859 on Tue May 21, 2013 6:17 pm
I have a snapped Aerial, and its starting to become annoying with every radio station having a mush of white noise .... Sad
Does anyone have one of these going at all, or know the best place to get one?
craig2859
Re: New Aerial
Post by leopard_pagan on Tue May 21, 2013 6:31 pm
+1 on this..
last "owner" bodged the aerial by sticking a bit of wood down the end & pushed it back on... errm.. it still doesnt work ya prat!
i know there are all sorts available out there, i dont want to spend much as i use the ipod more than radio. just looks silly with 5" of aerial
Re: New Aerial
Post by Manuel_nl on Tue May 21, 2013 6:54 pm
They are verry common aerils. You find them on ebay: http://www.ebay.nl/itm/Daihatsu-Hi-Jet-Hijet-Porter-Pillar-Aerial-Antenna-/400177101719?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item5d2c69fb97
I think they are sold in every local automotiveshop.
Manuel_nl
Re: New Aerial
Post by HighlyJetted on Tue May 21, 2013 7:01 pm
Re: New Aerial
Snap!
Re: New Aerial
Post by leopard_pagan on Tue May 21, 2013 10:06 pm
Got the one from 2 nd link. Looks more like what was on the van. :0)
& I did search for aerials but didn't put "Hijet" in... Doh!
Re: New Aerial
Post by craig2859 on Wed May 22, 2013 9:13 pm
Perfect, Ebay to the rescue once more
Cheers
craig2859
Re: New Aerial
Post by HighlyJetted on Wed May 22, 2013 9:50 pm
I would suggest that universal aerials do no quite fit the curve of the pillar perfectly.
So when you install make sure you seal everything up well with some silicon.
Otherwise you'll have a wet drivers side carpet and in the end it will cause more rot.
Re: New Aerial
Post by rich the mechanic on Wed May 22, 2013 10:17 pm
HighlyJetted wrote:I would suggest that universal aerials do no quite fit the curve of the pillar perfectly.
The mounting point on the pillar has a flat area for the base of the ariel.
Re: New Aerial
Post by HighlyJetted on Wed May 22, 2013 10:36 pm
The one I took off my pickup was this one:-
http://www.ebay.co.uk/itm/Daihatsu-Hi-Jet-Hijet-Porter-Pillar-Aerial-Antenna-/400177101719
And the mounts did not match the shape of the van, water had been running down the inside of the A pillar and into the footwell where it had caused alot of corrosion.
Re: New Aerial
Post by leopard_pagan on Sat May 25, 2013 12:53 pm
fitted.. i did cut/join the old wire to the new one..
silicone seal also used (ta 4 the tip)
& working..
feck its a long un when fully extended! feel the urge to tie a smurf flag to the end.. pmsl
Re: New Aerial
