What is this wire?! Should it be connected?!!
Post by HiJetSi on Thu May 23, 2013 6:15 pm
I noticed this set of wires is disconnected. I have a prince LPG system. Should this be connected/earthed to the engine block??
HiJetSi
Re: What is this wire?! Should it be connected?!!
Post by HighlyJetted on Thu May 23, 2013 7:07 pm
Yes it should.
Post by HiJetSi on Thu May 23, 2013 7:34 pm
OK, I will connect it to the block. What does it do? It leads to an 'igniter'?!
HiJetSi
Post by HighlyJetted on Thu May 23, 2013 8:13 pm
Yeah I think they are ground for the coils and the injectors and other pretty important stuff!
There is a bolt in the inlet manifold they are suppose to go to, right next to the flange from memory.
Post by HiJetSi on Thu May 23, 2013 8:16 pm
Ah OK! I thought it may have been disconnected due to the LPG system, but I will reconnect it. Maybe this will solve some of my problems...!
HiJetSi
