2 Fault Codes Appeared...HELP!
Post by HiJetSi on Thu May 23, 2013 8:05 pm
I have two fault codes...
42 – Coolant temperature sensor – open or shorted
52 – Vehicle speed sensor signal – open or shorted
My van has a hunting idle - perhaps error 42 is to blame?!
My van does however read the correct speed as far as I am aware so not sure what code 52 is all about!
Can anyone please help me!
HiJetSi
Re: 2 Fault Codes Appeared...HELP!
Post by HighlyJetted on Thu May 23, 2013 8:16 pm
I think those dodgy ground wires might not be helping with these.
Coolant sensor open will destroy your economy, as will the VSS error.
I think your hunting is because you have no coolant in that idle control valve - its pretty much an automatic choke.
Post by HiJetSi on Thu May 23, 2013 8:18 pm
OK. Thanks.
The economy was terrible actually when I drove it a fair distance. Might explain a lot...I'm learning a lot about Hi Jets all of a sudden! Very Happy
HiJetSi
Post by HighlyJetted on Thu May 23, 2013 8:22 pm
They are a good place to learn about EFi cars because they are one of the most simple installations I've worked on.
Post by HighlyJetted on Thu May 23, 2013 8:23 pm
I'd also say very effective and efficient too - the engineering is bang to the point, no frills, no undercutting. Just perfect!
Post by HiJetSi on Thu May 30, 2013 12:15 pm
Right,
Connected that earth and now only one fault code:
HiJetSi
Post by HighlyJetted on Thu May 30, 2013 2:45 pm
That's on the back of your cylinder head, cam sensor end
