Vibrating/rough pulling
Page 1 of 2 1, 2  Next
Post by 8bit-ash on Mon Jun 17, 2013 8:33 pm
Havn't had the chance to get under the van to have a look yet but since I did a couple of 100+ mile drives over the weekend the van has developed a fairly bad vibration type noise/feel.  It seems to be much more prominent when accelerating under load and feels like its transferring through the driveshaft/axle.  Anyone experienced this?
Re: Vibrating/rough pulling
Post by HighlyJetted on Mon Jun 17, 2013 9:05 pm
Nope, but my first look would be at the propshaft, as maybe the UJ had failed and was really stiff.
Logans prop shaft failed but just made noise, although they are very common failure item.
http://hijet.findtalk.biz/t1346-noises-from-my-back-end
Post by 8bit-ash on Mon Jun 17, 2013 9:30 pm
that was my first thought. do they show visible wear before detaching?
Post by HighlyJetted on Mon Jun 17, 2013 9:49 pm
??? The million dollar question.
On the good side though, you can get the prop shaft off in less than 10 minutes and you don't even have to jack it up like a normal car.
Well that is unless you've lowered it like a ricer Wink
Post by Guest on Mon Jun 17, 2013 10:13 pm
Its your propshaft on its way out Ash. Get underneath and check the joints for wear and as HJ says easy enough to drop the prop.
I have repaired hundreds -- in fact over a thousand Staked Propjoints on Fords, VW Transporters, Transits BMW's and other RWD vehicles. In one case on a Mk2 Escort the front joint let go and the prop dug in the road and flipped the car over and wrote it off.
that cant happen on a Hi-Jet as the prop is too short but it can take out brake and fuel lines and make a right mess off the floor pan.
I have seen that on numerous occasions. If the rear one lets go on a Hi-Jet the prop will fall
off as its on a sliding spline and that happened on a Cortina and it hit the car behind.
I am going to contact the Company I used to deal with and see if they can supply Staked Joints for Hi-Jets and if so I will do a replacement service on Hi-Jet props.
Will keep you all informed. Please check that prop out before driving it again Ash.
Post by Logi on Tue Jun 18, 2013 6:08 am
Is the pickup different?
Look for porter propshaft on ebay. i cant link to it cos im on my phone and something about the site has changed.
Post by Guest on Tue Jun 18, 2013 6:38 am
There is a 20mm difference in length, and not interchangeable. The Pickup prop is 340 mm centre
to centre of cups and the vans are 320mm centre to centre. Doesnt sound a lot but the longer prop on a van when under full load of weight can damage rear of gearbox.
Post by 8bit-ash on Tue Jun 18, 2013 5:34 pm
Well its definitely the prop shaft -
Hard to tell from the pic but don't think it was far from detaching.  Which are the recall ones the ones with or without the sirclips?
Post by d1noh on Tue Jun 18, 2013 6:43 pm
O dear,,,,,,,didn't know the pick up was different to the van, if true I have a van prop for sale
Post by HighlyJetted on Tue Jun 18, 2013 9:13 pm
Yep, van and pickup are different.
Have had them on the floor next to each other. There is a picture on here somewhere
Post by Guest on Tue Jun 18, 2013 9:30 pm
8bit-ash wrote:Well its definitely the prop shaft -
Well  I am glad you took it off Ash. You are lucky in that you have got replaceable joints rather than Staked joints-- provided you can find a supplier
of the circlipped joints.
I have found my WHOLE Staked Propjoint Replacement Kit for all 3 sizes of joints, 22mm, 25mm and 27mm. It cost me over £600 0ver 20 years ago.
I will try and contact my old supplier and see if they can supply the Hi-Jet Joints--- if so we are up and running Baby-- A Hi-Jet propjoint replacement  service.
Post by 8bit-ash on Tue Jun 18, 2013 9:46 pm
theres a listing on ebay for uj's that fit hijets i see.
Post by Guest on Tue Jun 18, 2013 10:02 pm
8bit-ash wrote:theres a listing on ebay for uj's that fit hijets i see.
Are they Staked ones or Circliped ones Ash ?? Can you post the link please.
Post by HighlyJetted on Tue Jun 18, 2013 10:39 pm
ADD63904
20.02mm Diameter
54.6mm Overall Length
Listed on Italian web sites to fit the Piaggio Porter from 1992 till 2012
http://www.iauto.lt/detales/3017882/0/Joint_propshaft_ADD63904_BLUE_PRINT
I say that looks pretty promising but a few little measurements would answer your questions!
Post by HighlyJetted on Tue Jun 18, 2013 10:42 pm
And just incase, but I'm sure your clued up already - I fit UJ's in my vice at home with no problems. No special tools needed, just some ye-olde techniques, using sockets and the vice.
Post by 8bit-ash on Thu Jun 20, 2013 5:19 pm
Got the UJ off today, the ebay ones don't seem to measure up to mine according to those measurements in the lithuanian site. Crying or Very sad
May have some progress with the recall though trouble is I need it for next weekend.
Post by HighlyJetted on Thu Jun 20, 2013 5:26 pm
Lituanian / Itallian - What's the difference Embarassed
What measurements do you get?
Post by 8bit-ash on Thu Jun 20, 2013 5:30 pm
Google chrome told me it was in lithuanian.  noticed the .it address though confused.
26mm diameter and about 61mm length.  Thats with the caps(or whatever the technical term is) attached.
Post by HighlyJetted on Thu Jun 20, 2013 5:34 pm
What about this one:-
http://www.sparepartstore24.co.uk/2164174-japanparts
Length [mm]58
Fitted Diameter [mm]22,5
Part numbers for the same joint:-
ASHIKA JO601
DAIHATSU 0437187502
DAIHATSU 043718...
DAIHATSU 0437187503
DAIHATSU 0437187506
NIPPARTS J2926002
NPS D283U02
Post by 8bit-ash on Thu Jun 20, 2013 5:44 pm
Thats deffo too small a diameter.  Mines 26mm minimum, probably 26.5ish.
Post by HighlyJetted on Thu Jun 20, 2013 5:46 pm
Others list it as 59mm x 23mm
UJ's are measure with the caps on - so total width and cap diameter.
This might help you find it too:-
http://www.hardyspicer.com.au/PDF_Files/Driveline/B1_Ujoints_and_Bearings_2010-12.pdf
Post by d1noh on Fri Jun 21, 2013 5:40 pm
I am hear to learn as well as help, I know prop shafts fail fact but this is bugging me,
If the van shaft is longer by 20mm and the spring hangers are longer on a van by 20mm than on a pickup, if the van is lowered and the prop shaft not shortened would that put extra strain on the uj or am I am going daft?
Post by 8bit-ash on Fri Jun 21, 2013 5:50 pm
If anything theres probably less strain on mine as its a straighter path from the gearbox to the axle.  Thats my thinking anyway.
Post by rich the mechanic on Fri Jun 21, 2013 8:18 pm
d1noh wrote:I am hear to learn as well as help, I know prop shafts fail fact but this is bugging me,
The pick up chassis is different and the travel of the sliding part of the prop is relative to the amount of maximum travel so unless you notch the chassis it won't make a bit of difference.
Post by d1noh on Fri Jun 21, 2013 9:01 pm
I can see that angle getting less which is better
Sorry not getting this and not doubting you either
Prop slides in and out with axle travel agreed, so if the axle is moved closer to it's upper most position when hitting a bump would it not go past the point where it would have maxed out before in the original position, wouldn't the prop to be shorter?
Shall I get me coat?
Post by HighlyJetted on Fri Jun 21, 2013 9:19 pm
Hiker prop shafts were made with cheap crappy UJ's it would seem, just like the thermostats.
Post by Guest on Fri Jun 21, 2013 10:08 pm
[quote="d1noh"]I can see that angle getting less which is better
Shall I get me coat?[/quote
Hi dinoh. See you are struggling with this one. If you look under your van you will see that the propshaft because they are so short, sit at quite an accute angle. As the axle travels upwards ( or the body downwards ) it prescribe an arc from
the front spring mounting on the chassis causing the prop to move forward .
To see for yourself get a few friends to sit one at a time in the back and watch the body come down further and further
and just see how much it slides further into the gearbox. You may get away with the longer prop but I wouldnt chance it.
Also the whole axle moves forward too when you give it a real bootfull . If you are really travelling at speed over a bad road surface that could also make it move further forward or backwards too.
Post by d1noh on Fri Jun 21, 2013 10:23 pm
Thanks Woody
100% undersand that but been tryng to put in to words what Im trying to ask
Here goes
At what point will the prop bottom out, lifting the axle higher from the standard position would it not get closer to the prop bottoming out?
Post by HighlyJetted on Fri Jun 21, 2013 10:35 pm
Well it should not bottom out till at least your on the bump stops.
