radiator fan on constant
Post by melboy on Sun Jun 23, 2013 4:40 pm
as title says my fans on constant,ive looked under rad and theres a white connecter with two wires hanging
loose at the bottom,so its possable that last owner took it off because of over heating or its come loose.
have any of you guys had any expeirance of this.
dont know if i should leave well alone or what.affraid
melboy
Re: radiator fan on constant
Post by HighlyJetted on Sun Jun 23, 2013 4:47 pm
Fan on constantly will:-
Ruin the fan
Reduce battery lifespan
Reduce alternator lifespan
Reduce fuel efficiency
How long have you had the van?
What does the temperature gauge say?
How much water is in the header tank?
What colour is the water?
How much water is there under the metal cap?
Post by melboy on Sun Jun 23, 2013 4:53 pm
had the van a week and it not using water and its pink colour.
the temp stays at the middle.
melboy
Post by rich the mechanic on Sun Jun 23, 2013 4:57 pm
I think the fan switch in the rad has failed and the conector has been shorted to keep the fan on, so get a new switch and plug it all in properly.
Post by melboy on Sun Jun 23, 2013 4:59 pm
thanks ,will give it a go at plugging in loose one first.
melboy
