REMOVAL OF DASH
REMOVAL OF DASH
Post by lestersteve on Sun Jul 28, 2013 1:46 pm
CAN ANY ONE HELP WITH THE REMOVAL OF DASH ON DIESAL HIJET VAN AS NEED NEW WIPER MOTOR
lestersteve
Re: REMOVAL OF DASH
Post by HighlyJetted on Sun Jul 28, 2013 4:47 pm
yes, it's quite easy to remove the dash board actually.
Also I have a spare working wiper motor.
Re: REMOVAL OF DASH
Post by xxemaphorr on Tue Jul 30, 2013 5:00 pm
it gets easier after the fourth or fifth time!Wink
xxemaphorr
Re: REMOVAL OF DASH
Post by Logi on Tue Jul 30, 2013 6:28 pm
lestersteve wrote:CAN ANY ONE HELP WITH THE REMOVAL OF THE CAPS LOCK ON MY KEYBOARD
lol!
Re: REMOVAL OF DASH
Post by chinfuk on Tue Aug 06, 2013 12:27 pm
hi, how do you remove the dash please, any hidden bolts or anything to watch out for, cheers. also does the little panel in the middle of the dash just pull out cheers
chinfuk
Re: REMOVAL OF DASH
Post by HighlyJetted on Tue Aug 06, 2013 6:16 pm
Hey!!
http://www.daihatsuhijet.co.uk/how-to-remove-the-hijet-dash-board-and-wiper-motor/
Although I did miss out the two bolts from the above guide that hold it the brake fluid bottle Laughing
Re: REMOVAL OF DASH
Post by chinfuk on Tue Aug 06, 2013 9:54 pm
thanks HighlyJetted, your a massive help. Hero!
chinfuk
Re: REMOVAL OF DASH
Post by CoolJet on Mon Jul 24, 2017 3:40 pm
Hi Folks!
Server is down... Is there any chance i can see that info somehow? My front wipers wont move. Motor seems to hearably work though.
Cheers!
CoolJet
Re: REMOVAL OF DASH
Post by Woodie on Mon Jul 24, 2017 11:13 pm
You won't be able to reach the server anymore. It was Highly Jetted's own site and he closed it down quite some while ago.
He was forwarding all the spares enquiries through to me and when I packed up due to too much demand for spares around the world he shut the site down very sadly.
Re: REMOVAL OF DASH
Post by Woodie on Mon Jul 24, 2017 11:21 pm
It sounds like the nylon ball joint socket has come off the motor arm. If you can move the arms both together then it is likely to be that or the 10mm nut on the operating arm has worked loose and may have stripped the very fine splines on the drive shaft. Either way it is a complete dashboard out job.
Should take no longer than 20-30 minutes to get it out. Provided you have a a quarter inch drive socket set and loads of patience and enginuity.
Re: REMOVAL OF DASH
Post by Manuel_nl on Tue Jul 25, 2017 10:36 am
Manuel_nl
Re: REMOVAL OF DASH
Post by Woodie on Tue Jul 25, 2017 10:41 am
Oh well done Manual. There is always more wisdom in a plethora of minds.
Re: REMOVAL OF DASH
Post by CoolJet on Tue Jul 25, 2017 11:32 am
Thanks lads!
Indeed very sad with the website. It held so much valuable infos. Maybe we can put the stuff on another server? I have webspace that could properbly host the site. At least a read only version as i dont have wordpress available i think.
Anyways you guys are awesome. I am very greatfull for the support. Hopefully no parts are fubar and i can get it back together.
Also the wipers always moved too far while it was still functioning. It went a bit over the edge of the window on either side, bottom and top. Maybe i can adjust that too while i am on it.
CoolJet
Re: REMOVAL OF DASH
Post by CoolJet on Thu Jul 27, 2017 9:25 pm
Did it today. Speedo Cable drove me nuts till i finally managed to rip it off pulling on the cable not the sleeve.
....and it was the ball joint. afro
Check out the pictures i took!
PS. I also needed a tiny phillips driver to undo the little screw holding the button of the choke leverage in place. Dont just rip it off  queen
CoolJet
Re: REMOVAL OF DASH
Post by mu0chn on Tue Aug 08, 2017 5:53 pm
Is it possible to remove the motor with out taking the whole dash out. My wipers have now stopped working all together.
mu0chn
Re: REMOVAL OF DASH
Post by Raggy on Tue Aug 08, 2017 6:26 pm
Stopped working as in no sound or whirling of motor but no motion?
Re: REMOVAL OF DASH
Post by mu0chn on Wed Aug 09, 2017 9:37 am
No sound no motion no see.
When I bought the van the wipers were slow and had to use the fast setting. Sometimes I had to give them a push to get them started. Now nothing.
mu0chn
Re: REMOVAL OF DASH
Post by CoolJet on Wed Aug 09, 2017 9:39 am
No way to get the motor out without dash out. Motor not making any noise? Have you checked the fuse and relay for the wiper already? They should be accessable without the dash job.
CoolJet
Re: REMOVAL OF DASH
Post by mu0chn on Wed Aug 09, 2017 10:49 am
I have not checked the fuse, will try and have a look later. Where is the relay. May try putting my amp meter in line to see if it is drawing any current.
mu0chn
Re: REMOVAL OF DASH
Post by CoolJet on Wed Aug 09, 2017 12:50 pm
I dont know exactly wich relay/fuse is the one for the wipers. U can find it in he manual section i guess. Check the fuse first. If the motor doesnt move instantly on receiving voltage it will draw high current and may have killed the fuse. But its just a feeling.
And dont kill your Meter. Might draw more than 10 amps.
CoolJet
Re: REMOVAL OF DASH
Post by Woodie on Wed Aug 09, 2017 2:36 pm
That is a very good point CJ. I must admit that I had overlooked that possibility. It could be the intermittent /continual wipe relay causing the problem.
Reading back on your post if you are having to give the wipers a push to get them going then I would say that the problem is definitely the Wiper Motor - be it the motor itself or the fragile self parking contacts.
If it is either then it is a dashboard out job.
Re: REMOVAL OF DASH
Post by Woodie on Wed Aug 09, 2017 2:43 pm
97
Just been out to the store and dug out a complete loom.
The Wiper Relay as you can hopefully see is directly above the square fuse-box. You can remove the whole assembly
by removing the two Phillips screws. Pretty easy to get at.
Re: REMOVAL OF DASH
Post by Woodie on Wed Aug 09, 2017 2:46 pm
Rotate the picture 90° right. Square lid is missing in this picture.
Re: REMOVAL OF DASH
Post by mu0chn on Wed Aug 09, 2017 8:19 pm
I have one of these. It has a 20 amp fuse in the side of it.
mu0chn
Re: REMOVAL OF DASH
Post by CoolJet on Wed Aug 09, 2017 9:26 pm
Nice one. Thats conveniant metering.
CoolJet
Re: REMOVAL OF DASH
