Can't remove crankshaft pulley on '99 hijet
Post by stevelav on Wed Aug 07, 2013 6:49 pm
i, I'm trying to get in to replace my timing belt (I think its about time being 14 years old) but I can't get the crankshaft pulley off to get the timing belt cover off.
I got the 4 small bolts off OK but the big one in the middle is stuck fast. I have the engine in 5th gear to hold it still and I'm using a 30 cm ratchet handle and pulling as hard as I can but it will not budge one bit (except to try and roll backwards)
Any tips?
stevelav
Re: Can't remove crankshaft pulley on '99 hijet
Post by xxemaphorr on Wed Aug 07, 2013 7:03 pm
manual shows this:
So its that easy! Just remove it!
I used a windy gun on mine but make sure you use impact sockets
xxemaphorr
Post by stevelav on Wed Aug 07, 2013 7:07 pm
That's what I've been following.
In the second picture I get the 4 small bolts off no probs but the big one in the middle is stuck fast so I can't get the pulley off.
stevelav
Post by stevelav on Wed Aug 07, 2013 7:10 pm
Unless I'm being v stupid and the pulley comes off without removing the big nut!
Though my pulley still seems firmly attached.
stevelav
Post by xxemaphorr on Wed Aug 07, 2013 7:16 pm
No I think you might be right on that. Not sure what I was thinkin of there. Maybe a puller to seperate? Or some gentle persuasion with a copper mallet?
xxemaphorr
Post by stevelav on Wed Aug 07, 2013 7:32 pm
well stuck
stevelav
Post by HighlyJetted on Wed Aug 07, 2013 7:32 pm
You don't remove the big one in the middle!!!!
Just remove the 4 10mm's and then the V belt pulley comes off.
Then remove all your timing belt plastics, undo the tensioner and hey presto the belt is off.
Post by xxemaphorr on Wed Aug 07, 2013 7:38 pm
yeah just give it a tap around the outside if you don't have a puller to push on the centre bolt and pull the pulley off. If you damage it I;m sure HJ will have a spare available!
xxemaphorr
Post by stevelav on Wed Aug 07, 2013 7:57 pm
Does it really come off like that!
I'll try again in a bit.
I did wonder but then in my picture it looked like the big nut holds it on.
Thank you v much
stevelav
