Lots of gunk under oil filler cap
Post by stevelav on Wed Aug 07, 2013 11:03 pm
Is this bad?
[img][/img]
do I need to clean it out?
stevelav
Re: Lots of gunk under oil filler cap
Post by rich the mechanic on Thu Aug 08, 2013 7:05 pm
Errmmmm! Yes - yes it does that it burnt or caramelised oil which means it's got bloody hot at some point or the headgaskets blowing into the oil ways.
Post by HighlyJetted on Thu Aug 08, 2013 7:14 pm
Looks pretty grim, looks like its neglected one way or another.
I see you have an LPG one! Wonder if its a Fulham council one?
Post by stevelav on Thu Aug 08, 2013 7:42 pm
Yeah I've took it off to clean it looks pretty nasty.
Not sure exactly where it came from, I bought it off a lady in bath though I think it did come from London. It is in v good cond for year with only 60000 miles so maybe its ex council?
stevelav
Post by PFM on Thu Aug 08, 2013 8:10 pm
If it's not over-heating, I'd treat it to an engine flush and new oil and filter smartish.
Post by stevelav on Thu Aug 08, 2013 8:25 pm
Thanks, those are my next jobs after timing belt!
No overheating and the oil actually looks great in the engine nice golden brown its just full of that crusty hard deposit at the top of the filler pipe.
Hopefully its not indicative of a deeper problem!
stevelav
Post by PFM on Thu Aug 08, 2013 10:23 pm
IMHO crusty hard deposits are never good! Maybe Logi has an opinion?
Post by HighlyJetted on Fri Aug 09, 2013 12:46 am
I have never seen an oil crust build up like this on anything before, it almost look like beads.
Maybe its had some kind of additive put in the oil at some point? Just a wild guess like.
Is it hard or sludgy? Peel some out and spread it like butter on some white paper and post another photo.
Post by Logi on Fri Aug 09, 2013 5:52 am
PFM wrote:IMHO crusty hard deposits are never good! Maybe Logi has an opinion?
Yeah, Bold 3in 1, works well with crusty deposits on sheets......Wink
Mines had something similar, whats the mileage? Mine had 8k done in 1/2 mile segments. Loads of short journeys can cause it( or the hg is f*cked)
Post by stevelav on Fri Aug 09, 2013 6:19 am
Thanks for the replies.
I've cleaned it all off now but it was actually milky brown oil lower down which I guess dried at the top to make the hard crusty stuff in the pic and the pipe narrows there which made me think it was really thick when its just the pipe narrowing.
Hopefully its just hot engine vapour condensed on the tubing built up over time and not a dreaded head gasket failure!
I think Logi's saying you can get it from lots of short journeys
I'll def keep an eye on it now though
stevelav
Post by rich the mechanic on Fri Aug 09, 2013 8:15 pm
Just a thought there is a smoke stop product for adding to oil to reduce the smoke from valve stem and piston ring wear it is a bodge that I only look at while trying to find a product I do want that works. Which is just like the crap and dodgy dealers we were talking about the other day talking of which I had to fix a pair of wheels that were wrong on a bike sold by a dealer, front was just offset wrong the rear however was a death trap the hub was cracked around the mounting point for the drive/drum mount and dished wrong and most of the spokes on the drive side had a few mm of thread holding the nipples on.
Post by 8bit-ash on Fri Aug 09, 2013 10:13 pm
If you're part of the V--- KKJ family it'll probably be an ex Fulham and hammersmith council van.
Post by stevelav on Fri Aug 09, 2013 10:54 pm
Well fancy that it is a V--- KKJ plate.
They prob used it for lots of short trips too helping gunge up the oil pipe!
stevelav
