Low Jet Hi Jet
Low Jet Hi Jet
Post by d1noh on Thu Aug 22, 2013 7:22 pm
advice required,
Told you my jets have to work for a living, bit excited about this job, had a call from one of the bosses today, wait for it,,,,,,, could I put a jetting unit on the back of my truck and go down the sewer tunnels, rain water only so no Poo, he tells me I have 2mts to play but with bends, my question, not under water but should the air supply for the engine be ok, anything else you can think of?
Dino
Re: Low Jet Hi Jet
Post by waz on Thu Aug 22, 2013 7:30 pm
Can't answer your question but sounds good, will he be paying a good rate for the use of the van?
Re: Low Jet Hi Jet
Post by Logi on Thu Aug 22, 2013 7:37 pm
Wellies? Smile
Re: Low Jet Hi Jet
Post by d1noh on Thu Aug 22, 2013 7:44 pm
they are all working jet and being the council always pay, wellies are a good call, better reversing lights incase the roof working lights fail, good tow rope incase it brakes down or gets stuck Laughing
A blue and red pick up and a video camera Twisted Evil
Re: Low Jet Hi Jet
Post by rich the mechanic on Thu Aug 22, 2013 8:11 pm
Air supply should be good the lower you go the more dense the air gets so the motors might make an extra horse power. But I think I would run a couple of leisure batteries as you don't want them running at a standstill if working nearby and they can run the lights for that and if you do have a break down your not stuck in the dark.
Re: Low Jet Hi Jet
Post by d1noh on Thu Aug 22, 2013 8:31 pm
thanks Rich, they will go on the shopping list 100%
Re: Low Jet Hi Jet
Post by Logi on Thu Aug 22, 2013 8:43 pm
Re: Low Jet Hi Jet
Post by d1noh on Thu Aug 22, 2013 8:49 pm
pmsl Laughing  Laughing  Laughing
Re: Low Jet Hi Jet
Post by rich the mechanic on Thu Aug 22, 2013 9:27 pm
Also think that the grills should be held on with old leather belts and put three spots on the front just for the full effect.
Re: Low Jet Hi Jet
Post by HighlyJetted on Fri Aug 23, 2013 12:40 am
Hijets are poor when driving though water as the under covers to the engine area are poor. I would look at some extra bits of sheet that stops the front splash up from getting onto the pulley area.
Also I would look at moving the air intake to the rear wall of the cab like a truck, maybe the exhaust too, make sure all the HT lead area seals up well, as you may have to wade it though a couple of foot of water.
Realistically they ain't going to be going very fast so your typical kenlow fan setup.
You want one of those drain gas monitors and a breathing bottle setup, as you can get toxic gas build up in underground pipework.
Obviously you need big fat water tank, pump and lance setup, plenty of lighting!
You'll get no phone signal, nor will radios work - so if you get stuck or lost - well good luck!
Will a hijet even fit in the underground drain work?
A 4x4 one might go along way is its going to be wet and slippery.
And you may go down a section then find you have to do a lot of reversing to get back out.
Re: Low Jet Hi Jet
Post by Guest on Fri Aug 23, 2013 6:44 am
Think I would want to walk it first --- in Waders. Very Happy Very Happy
Re: Low Jet Hi Jet
