WANTED , 2 x rear light clusters and a O/S indicator lens for my P reg Hijet,
Post by eddie0303 on Fri Aug 23, 2013 9:38 am
Hi All , I am looking for the following parts for my P reg Hijet van . 2 x rear light clusters / lenses . 1 x O/S indicator lens , its the older type with the yellow and clear glass above each other . An interior door handle for the O/S sliding door , Radiator caps for both the high mounted rad and the filler on top of the rocker cover , its the 993 petrol engine .
Many thanks Eddie , P.S my phone number is 07816 374155
eddie0303
Re: WANTED , 2 x rear light clusters and a O/S indicator lens for my P reg Hijet,
Post by Guest on Fri Aug 23, 2013 2:33 pm
Try HJ first Eddie as it is his living --- this at the moment is spare time though
eventually by the years end, will end up full time. If no joy with HJ then yes I
have got all that Eddie. Buy new radcaps from your local motor factors though.
07970 391876. Woody.
Thanks to Woody and Matt
Post by eddie0303 on Fri Aug 23, 2013 4:43 pm
Many thanks to you both I now have all the bits I need to get it finished . Best regards and hope to chat again at some point
All the Best
Eddie
eddie0303
Post by HighlyJetted on Fri Aug 23, 2013 8:48 pm
Excellent stuff, might not be like walking into a shop, but we're more likely to get the right bits to you.
