Hijet EFI '01 Main Fuse(s) Location?
Post by martinwinlow on Fri Jun 04, 2010 8:59 pm
Anyone tell me where they are? MW
martinwinlow
Re: Hijet EFI '01 Main Fuse(s) Location?
Post by Guest on Sun Jun 06, 2010 10:49 pm
I will happily tell you, in my 1.3 EFI they are to the left of the steering wheel and down a bit! Tucked away under and put of sight - hope that helps Very Happy
Post by martinwinlow on Sun Jun 06, 2010 11:48 pm
Hi, thanks, but that's just the 'ordinary' ones. The one I was after (well, 2 actually according to the wiring diagram) are elsewhere - one is 60A and the other is something else - both a lot bigger than the 'ordinary' ones for the horn etc. Mind you, it doesn't matter anymore anyway as it wasn't the main fuse that was causing my problem. It was the low power (small) connection to the +ve battery terminal that had rotted thru and dropped off! Simple fix for a very frustrating problem. Happy days! MW
martinwinlow
Post by Tukz on Mon Jun 07, 2010 5:58 pm
They are behind the dashboard either near or attached to the fuse box.
Tukz
http://www.tuktuktravel.co.uk
Post by HighlyJetted on Tue Jun 08, 2010 10:59 am
Martinwinlow, mine did the same although I only found out on a rainy midnight when I was nailing it down a B road and after hitting a few jumps the Van cut out, all the dash lights everything.
My battery clamp had come loose and the battery was flapping about in the box causing those little power wires to break from the banjo. Got it bodged up and still bodged to this day Smile
Post by PFM on Wed Feb 29, 2012 7:41 pm
The main fuse, or 'fusible link' as the handbook calls it, is under the driver's seat - look down at the front of the opening towards the crossmember, it's behind where your left heel would be if you kicked it back from the clutch.
