Breaking P reg 993cc Efi Hijet
Post by Little Black Van on Sun Aug 25, 2013 8:18 am
Ok, sad to say this, but my little steed is deceased. Head gasket went and after taking the engine apart and looking at it's other problems, such as rust and chronic overheating, as well as it still drinking oil like it's going out of fashion, I decided to call it a day. So I have a van being broken for parts, most of the parts are available for sale, just tell me what you're after and I'll get it sorted. As I sell items I will make a list in this post of what's been sold, so you know exactly what is and isn't available. If it's on the list, it's gone.
I also have a brand new timing tension pulley spring and gasket set for the 993cc CB42 Efi if anyone wants these items.
It's a black panel van, and I'm based near Llandysul, Carmarthenshire if anyone is near.
Broken:
N/S sliding door handle broken.
O/S door mirror broken
Sold:
N/S door mirror
Fuel cap
One lockstick cover
O/S indicator/sidelight block
Clutch and brake pedal covers
Last edited by Little Black Van on Sat Aug 31, 2013 4:53 pm; edited 3 times in total
Little Black Van
Re: Breaking P reg 993cc Efi Hijet
Post by neo piaggionisto on Sun Aug 25, 2013 8:32 am
Hello,
sorry for the loss of your beloved car, hope you will find another one Smile
I need some parts but I don't know if they will fit the model I own ? Mine is a S85-LPTRMDP (1.2D pick-up from 1996).
What I need so far (maybe more to come) is :
- the fuel cap
- rubber pad for clutch and brake pedals (the one missing on brake is a problem for the french equivalent of MOT)
- front right blinker glass block (don't know the english word for this)
- one of those tiny plastic sticks to lock the door
- wing mirror if still not flappy
Please let me know if this is available and if you would ship to France.
cheers,
Luc
neo piaggionisto
Post by PFM on Sun Aug 25, 2013 12:07 pm
Sorry to hear your sad news, LBV. Are you planning to get another?
Post by Guest on Sun Aug 25, 2013 12:12 pm
Ditto. If you are, will it be " A Little Black Van " again ? Cant have you changing your name to
" Little White Van ". Very Happy
Post by Little Black Van on Sun Aug 25, 2013 9:57 pm
Well, I have already replaced it with an S reg Golf in very nice condition, which for my life at the moment is exactly what I need. Times have changed for me since I got Bod (after the number plate) and a car with a bit more style for my age group is what I need. Besides, bod is bloody uncomfortable on long journeys...
Little Black Van
Post by HighlyJetted on Sun Aug 25, 2013 10:49 pm
"Style" What are you on about man,
Hijet turns more heads than anything else on the road.
They are just too cool for school
Post by Guest on Sun Aug 25, 2013 10:58 pm
Most of the heads over here turn and look at my Hi-Jet too HJ.---- usually in
amazement as I dare to overtake them in a vehicle not much bigger than a
postage stamp. Love it !!affraid
Post by Little Black Van on Sun Aug 25, 2013 11:02 pm
I know what you mean, and I agree they have their own style, and I may well get one again in a few years, but right now I'm better off with just a car.
Little Black Van
Post by HighlyJetted on Sun Aug 25, 2013 11:08 pm
I think a load of cars on the a34 on my way home tonight got the hijet suprise.
Following a long tailback of cars doing 45 on the A road,
I back off a bit before some complex corners,
Take my run up to get to a damn good speed,
Then ripped past the whole tail back taking the lead into some tight corners with the tyres screaming.
I often wonder what people must think!
Post by Guest on Sun Aug 25, 2013 11:13 pm
So no more posts from you then ? Bod. So it came from Devon in the
beginning then, OD being a Devon reg .confused
Post by Guest on Sun Aug 25, 2013 11:20 pm
Its going to be much more fun Matt with 1600 engines in our respective beasts.
I have decided to put it in the 05 plate Pickup with a tipper body.
The bonus is access to everything under the lift up bed and better access to
the rear of the engine too.Laughing Laughing
Post by HighlyJetted on Mon Aug 26, 2013 12:01 am
I much prefer working on vans than pickups.
Least in a van the whole engine is in front of you once you get the covers off.
Working on pickups is a bit of some stuff inside, some stuff outside, leaning in though the doors.
While in a van you can keep tools and stuff on the dash and on the floor and work dry even if its raining.
Speaking of 1.6 Hijets, I might have some good news about the pistons and rod issues to get the compression up, but I'll know more on tuesday. The engine building guy I use thinks the rods are the same so you might not have to change them over, simply keep the 1.3 pistons and rods and chuck them in the 1.6 block/crank
Post by Guest on Mon Aug 26, 2013 12:19 am
Yes it is more handy to have a van in the winter especially for me
with all the power tools I carry about on various kinds of jobs.
But I do find the pickup more fun to drive as you can really make them
slide and hang the tail out.
Access issues I certainly agree with that. That's why I am going
to use the tipper bodied one.
I have got a beheaded 1300 lump in the store so will look at it in the
morning-- oh it is morning now. I haven't taken any notice of the piston
crowns before. If fitting 1300 pistons increase the CR then
presumably they are hemi ones and must be a higher profile than
the 1600 ones.
Post by HighlyJetted on Mon Aug 26, 2013 12:33 am
Yes 1300 pistons have protuding crowns while the 1600 ones are pretty much flat. Compression ratios go like this (taken from an Diahard the aussie Daihatsu website):-
1.3 HC-E: 9.5:1
1.6 HD-E: 9.5:1
1.5 HE-E: 9.5:1
Theoretical hybrid compression ratios:-
1.6 HD crank/block with 1.3 HC pistons: 11.06:1
1.3 HC crank/block with 1.6 HD pistons: 7.83:1
Post by Little Black Van on Mon Aug 26, 2013 8:27 am
woody wrote:So no more posts from you then ?  Bod. So it came from Devon in the
Yep, it did indeed. Also where I originally came from. No more hijet posts from me for this beastie I'm afraid, Though I'll stick around a bit and try and help others if I can.
Little Black Van
Post by Little Black Van on Thu Aug 29, 2013 5:38 pm
By the way, it also has two almost brand new tyres with 6-7mm tread and one new ish tyre with 5mm tread, all on rims, if anyone's interested.
Little Black Van
Post by eddie0303 on Thu Aug 29, 2013 6:26 pm
Hi L.B.V , I am looking for the lock mechanism / lock for the drivers side sliding door , can you give me the cost of of it and the postage to Blackpool area .
Many Thanks
Eddie
eddie0303
Post by eddie0303 on Fri Aug 30, 2013 9:26 am
FAO LBV , I have now managed to find a lock for the van ,but thanks anyway.
Cheers
Eddie
eddie0303
Post by Little Black Van on Fri Aug 30, 2013 5:12 pm
No problem, sorry I didn't get to you quick enough. Smile
Little Black Van
parts which dont fit
Post by Richard1943 on Tue Sep 03, 2013 4:06 pm
I'm looking for track control arms for my son's 1999 hijet I bought some online but they have threaded ends and his one uses pinch bolts,I wonder if you still have them on your deceased steed
Richard1943
Post by Little Black Van on Tue Sep 03, 2013 5:19 pm
I'll have a look for you, I definitely have them but not sure if they are the right type.
Little Black Van
Post by HighlyJetted on Tue Sep 03, 2013 5:48 pm
I've sold a couple of sets of track arms complete because of this problem.
You can change over to the more common type which is the bar is a hollow threaded tube, and the track rods have a threaded shaft
Post by Richard1943 on Tue Sep 03, 2013 7:50 pm
If they are original they should be right as long as they are not too worn..
Richard1943
Post by 20Buzz46 on Fri Sep 06, 2013 8:12 am
Hi. My 993 failed its MOT on rear brakes yesterday,(didn't register on the gauge). I'm on a tight timescale due to a charity trip to Rome on the 19th so I'm taking a guess it might be the load compensating valve and trying to obtain one before the garage strip it down.
If you have one available please could you let me know price and postage. Cheers Buzz
20Buzz46
Post by HighlyJetted on Fri Sep 06, 2013 10:06 am
20Buzz46 wrote:Hi. My 993 failed its MOT on rear brakes yesterday,(didn't register on the gauge). I'm on a tight timescale due to a charity trip to Rome on the 19th so I'm taking a guess it might be the load compensating valve and trying to obtain one before the garage strip it down.
Before you panic and make a big job....
Go to the van with a mate or assistant.
Crawl under the back of the van.
Is the arm on the lspv free to move? If no get it moving by wire brushing the pivot off, and wd-40, and keep moving it until properly free.
If the arm is free - push the arm against the valve block - get mate to press brake pedal - can you feel it push the arm back a little bit?
If you can feel it push back then the valve is OK. But the spring is probably worn out.
If the arm does not push back, flip the arm out of the way, take the rubber off the LSPV, clean out the grease or rust, spray it inside with some penatration oil, tap the centre pin with a hammer, then get your make to press the brake pedal really hard. If you can get that centre pin moving again then is OK.
Jack up the rear axle so the wheels are off the ground.
Push the arm against the valve - Get your mate to press the brake pedal - spin the rear wheel - Do the brake work?
Normally they will now the lever is pressed.
Go to an engineering company to buy a suitable spring, adjust the arm to the max via the bottom bolt on the axle - go and pass the MOT.
Replacing the LSPV is a bit of an arse as the brake pipes will tend to get damaged and the brakes will need a full re-bleed.
Post by 20Buzz46 on Fri Sep 06, 2013 11:12 am
Thanks HJ. Will print this off and take it to garage.
Is there anything you don't know about Hi-Jets?
Buzz
20Buzz46
Post by HighlyJetted on Fri Sep 06, 2013 11:59 am
Where to buy head lights from - How to stop them from rusting Laughing Laughing Laughing Laughing
