LPG VAN BREAKING
Page 2 of 2 Previous  1, 2
Re: LPG VAN BREAKING
Post by d1noh on Sun Sep 01, 2013 7:03 pm
Re: Eek (again) LPG tank leaks
.Got some details from the old post
Sat on a back of a hijet pickup with a metal cover over it
60cm Long 30 Diameter
Cap 35l
21.8.98
R O59132
57R 00A92002
VL. TP. GPL 5001
WVM1770
LPG25/PE 30BAR
you said yours is a 25ltr? if so the max you would have ever got in it would be 18ish ltr, you can only fill a LPG tank to 80%
Post by elfin girl on Sun Sep 01, 2013 8:09 pm
hmm, maybe its not 25lt ill go and measure up! ill give the garage a ring tommorow and find out if they will put on a second hand tank and how much theyll charge go from there! i can give them the details of the tank youve got
just had a quick measure up in the dark but pretty sure mines closer to 50cm x 20cm, and yet when i fill from empty it fits almost 25lt i dont think there would be space for a tank 60cm and its already quite low even tho there is no space at the top so 30cm diameter might be low enough to hit the curb!
ill see what information i can glean from the garage, hopefully they have dealt with hijets and can help over the phone
ill let you know what i find out :-)
Post by HighlyJetted on Sun Sep 01, 2013 8:36 pm
I think after 2001 they had a slightly different prins setup on them but I've not messed with enough to be 100% factual.
Post by d1noh on Sun Sep 01, 2013 8:42 pm
a tanks a tank... unless your erman the german sitting in his tank having a read of the beano ...
Post by elfin girl on Mon Sep 02, 2013 4:32 pm
well, just gave herts autotec a ring and im going to pop down when i get some spare time so they can have a look and tell me what it is ive got! and ill take the details of your tank so they can tell me if they are able to fit it
they were very friendly and helpful so im pretty optomistic about this
d1noh, I may want the tank i may not! if someone else wants it before im certain then dont worry about saving it!
4x4?
Post by Onyeredson on Mon Jul 14, 2014 8:06 am
d1noh wrote:Located 1 mile from J12 J13 M6 Staffordshire
Hi! Was wondering if 4x4? if it is I've tried to repair my layshaft oil seal in doing so the springs and ball bearings went everywhere so need a complete gearbox. Cheer's! Paul 'W' 07751 942000
Onyeredson
Post by d1noh on Mon Jul 14, 2014 2:22 pm
Sorry but that was 2wd, try ebay.de but search piaggio porter
Post by Onyeredson on Mon Jul 14, 2014 3:57 pm
Thank you for responding, will looksee.
Onyeredson
