rev counter
Page 1 of 4 1, 2, 3, 4  Next
rev counter
Post by HIJET1300GT on Sat Aug 31, 2013 3:03 pm
a little buy off ebay last week has landed so its time too crack a beer and fit it ! not sure to sure the best place on the dash to mount it tho, best place so far seams to be a side mount to the left of the speedo housing .
HIJET1300GT
Re: rev counter
Post by oldie on Sat Aug 31, 2013 3:50 pm
OooOooh, like that Twisted Evil .
How much and have you a link please.
Re: rev counter
Post by HighlyJetted on Sat Aug 31, 2013 4:00 pm
Is yours a 1300? I still need to wire mine in.
Re: rev counter
Post by HIJET1300GT on Sat Aug 31, 2013 4:06 pm
Hi oldie and HJ . I'm just fitting it in as we speak. Ill put a link up for you oldie to eBay it was 11.50 delivered.
HJ yes mine is a 1300 16v
HIJET1300GT
Re: rev counter
Post by HighlyJetted on Sat Aug 31, 2013 4:40 pm
Be interested to know where you wire it in to pick up the tacho signal
Re: rev counter
Post by HIJET1300GT on Sat Aug 31, 2013 4:52 pm
Under the dash HJ ,it's a 4pin white plug and its the yellow and black wire is the pulse signal .
Mines an early type that dose not have the diagnostic port.
HIJET1300GT
Re: rev counter
Post by eddie0303 on Sat Aug 31, 2013 5:09 pm
OOOOH Like that , will keep it i mind for a later add .
Cheers all
Eddie
eddie0303
Re: rev counter
Post by HIJET1300GT on Sat Aug 31, 2013 6:52 pm
ok right here is the like to ebang for oldie
http://www.ebay.co.uk/itm/52mm-2-Rev-Counter-Tacho-Tachometer-Gauge-With-White-Face-Blue-LED-0-8000-RPM-/360649794427?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item53f867237b
its not as cheap as i said but there are cheaper ones but they dont come with a pod.
first of all the mounting of it , i went for the left had side of the speedo binical as it didnt obstruct anything and it gave me a good viewing angle .
as you can see it was strait forward to mount , just two self taping screws and a 5mm hole for the cables to pass though.
once it was mounted it was just a case of abit of power and the pulse signal .
i took the power from the back of the fag lighter as it was the most accessible source of power that came on with the ignition.
Now for the pulse signal wire, my van is a early 1.3 16v with twin coil packs and no odb2  port. Having a poke around with the fluke multimeter i found the tacho output it was on a little 4pin connector just pokeing out of the loom to the right of the heater, it is right at the back and a right fucker to get to! the output was on the black and yellow wire.
As it was a right wanker to get too i made a little plug pin to stick in the connector out of a wire crimp and cut the end to a point , and then just taped it to stop it falling out.
once that was in it was switch on time!
A a quick blast down the A46 and all seem fine and dandy . its probably not the most accurate bit of kit but then it was £11.50 off Ebay. it dose the job tho, 70mph is about 4000 rpm .
HIJET1300GT
Re: rev counter
Post by HighlyJetted on Sat Aug 31, 2013 8:10 pm
Good work, you've taken all the work out of it for me too. Thanks for sharing and the great pictures too!
Re: rev counter
Post by HIJET1300GT on Sat Aug 31, 2013 8:53 pm
No problem hj. get on it and get it connected ! Very Happy
HIJET1300GT
Re: rev counter
Post by HIJET1300GT on Sat Aug 31, 2013 9:06 pm
found it oldie . this is the ebay tacho 11.58 delivered . came in 4 days. works ok . has a blue led back light (not my bag but im going to change the colour)
Last edited by HIJET1300GT on Sun Sep 01, 2013 8:13 am; edited 1 time in total (Reason for editing : Wrong link)
HIJET1300GT
Re: rev counter
Post by Guest on Sat Aug 31, 2013 9:11 pm
Excellent bit of work GT. Looks a really neat bit of work you have done
and all the exploratory work you have done too. Thank you very much.study
Re: rev counter
Post by HIJET1300GT on Sat Aug 31, 2013 9:39 pm
Thanks woody. hope it will help others.
HIJET1300GT
Re: rev counter
Post by Guest on Sat Aug 31, 2013 9:52 pm
I am sure it will GT---- me for one as I will buy two or three to keep on the shelf.
Gonna be a bit of cursing though getting my mobile bear traps into that small
space to reach that connector block.
Think my Grandaughter will be seconded to
do that for me. She loves tinkering with cars at only 11 years old. Takes after her Grandad definitely. Poor girl.!!
Re: rev counter
Post by HIJET1300GT on Sat Aug 31, 2013 10:02 pm
yes woody it sure is tight in there ive got cuts all up my arm from this job, worth it tho Very Happy if you have a willing small person then get her in there !
This is the early type 1.3 (NO odb2 connector)  pulse for tacho is on a black and yellow wire
This is the later type 1.3 with odb2 connector , it looks to me you should be able to hook your rev counter to a pin on this. its not as clear on the pic but it is also on a black and yellow wire according to this schematic.
HIJET1300GT
Re: rev counter
Post by HighlyJetted on Sun Sep 01, 2013 1:36 am
Tomorrows (erm todays) job will be putting my rev counter in my daily driver Cool
Re: rev counter
Post by Guest on Sun Sep 01, 2013 1:40 am
Good man . Well done and thank you. Might be calling you in a few days
when mine arrive. All of mine are the later ones with the diagnostic socket.
Re: rev counter
Post by Guest on Sun Sep 01, 2013 1:44 am
[quote="HighlyJetted"]Tomorrows (erm todays) job will be putting my rev counter in my daily driver Cool [/quote
Go to bed boy. You should have been there hours ago at your tender age.lol! Sleep
Re: rev counter
Post by Guest on Sun Sep 01, 2013 1:47 am
Oh thinking about it you probably were and now you have just got back
to your own bed.!!!Very Happy Very Happy Embarassed Embarassed
Re: rev counter
Post by oldie on Sun Sep 01, 2013 5:25 am
HIJET1300GT wrote:found it oldie . this is the ebay tacho 11.58 delivered . came in 4 days. works ok . has a blue led back light (not my bag but im going to change the colour)
http://www.ebay.co.uk/itm/2-52mm-Car-Motor-Counter-Tacho-Tachometer-Gauge-Meter-0-8000-RPM-Rev-Blue-LED-/290938085152?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item43bd42df20
Thanks for the linky and the fitting info....can't fault you.....cheers cheers .
Re: rev counter
Post by Guest on Sun Sep 01, 2013 7:26 am
I've had a look at the add on eBay now and I guess they must be selling 12volt
Tyre Pumps too. The Rev Counter price has been INFLATED to £15-99 now.
Still a good deal though at that. I sold three larger secondhand revcounters
at Beaulie Auto Jumble last September for £25 each.
Just going to order a couple of them now.sunny santa
Re: rev counter
Post by HIJET1300GT on Sun Sep 01, 2013 8:08 am
This is the eBay no for the 11.58 ones
290938085152
HIJET1300GT
Re: rev counter
Post by HIJET1300GT on Sun Sep 01, 2013 8:12 am
Hi woody they are still 11.58 . The link at the top was the wrong one the one lower down is the right one.
HIJET1300GT
Re: rev counter
Post by Guest on Sun Sep 01, 2013 9:36 am
Oh right thank you GT. Glad I haven't ordered it yet. I got distracted by
another matter. Obviously good timing in this case. Cheers for that.Very Happy Very Happy
Re: rev counter
Post by Guest on Sun Sep 01, 2013 10:03 am
Thank you very much for that GT. I have ordered two.
I tried ordering two at once but it wouldn't play ball and tried
to charge me £2-58 for postage for one.Its nice to know that modern
day computers can get befuddled--- not just old farts like me!!lol!
Re: rev counter
Post by HIJET1300GT on Sun Sep 01, 2013 10:13 am
Computers are a pain. Excellent news you didn't have to spend unnessasry wedge! Hope it was a good distraction like a big full English breakfast with a big mug of tea!
HIJET1300GT
Re: rev counter
Post by Guest on Sun Sep 01, 2013 10:20 am
Yes and no. Breakfast --- part of it --- mug of tea -- definitely not !!
Black coffee man me with plenty of sugar.Rolling Eyes Rolling Eyes
Re: rev counter
Post by xxemaphorr on Mon Sep 02, 2013 2:49 pm
That yellow/black rev wire runs to the 4 pin diagnostic port so you can just connect in to it there. This is where I put mine. Bit fiddly cutting the right space out of the instrument surround though
[img][/img]
xxemaphorr
Re: rev counter
Post by HIJET1300GT on Mon Sep 02, 2013 3:15 pm
xxemaphorr wrote:That yellow/black rev wire runs to the 4 pin diagnostic port so you can just connect in to it there. This is where I put mine. Bit fiddly cutting the right space out of the instrument surround though
Yep that's what I said.
HIJET1300GT
Re: rev counter
Post by Guest on Mon Sep 02, 2013 3:45 pm
Hi Gt . I did order a couple of Rev Counters , but it is showing a ridiculous
delivery date. How long did it take to get yours through please??
Re: rev counter
