rev counter
Page 2 of 4 Previous  1, 2, 3, 4  Next
Re: rev counter
Post by HIJET1300GT on Mon Sep 02, 2013 3:54 pm
Hi woody it says some silly date , it also said it was coming from hongkong but ordered mine on the 28th and it was on my door by the the 30th. My estimated date was 1st of oct.
HIJET1300GT
Re: rev counter
Post by Guest on Mon Sep 02, 2013 3:57 pm
Great!! Thank you very much GT. I had hoped that would be the case.
Re: rev counter
Post by Logi on Mon Sep 02, 2013 5:01 pm
I see a mod for the to do list Twisted Evil
Re: rev counter
Post by xxemaphorr on Mon Sep 02, 2013 5:05 pm
HIJET1300GT wrote:
xxemaphorr wrote:That yellow/black rev wire runs to the 4 pin diagnostic port so you can just connect in to it there. This is where I put mine. Bit fiddly cutting the right space out of the instrument surround though
Yep that's what I said.
So you did sorry I was work and didn't get to read it fully and got a bit giddy about someone else doing a rev counter! Very thorough
xxemaphorr
Re: rev counter
Post by HighlyJetted on Mon Sep 02, 2013 5:18 pm
Woah a 10k rpm counter, the hijet will use all of that for sure Laughing
I've just fitted mine in the same place as xxemaphorr.
Make it really easy just being able to plug it into the diagnostic connector.
Re: rev counter
Post by xxemaphorr on Mon Sep 02, 2013 5:22 pm
I sure the picture of HIJET1300GT while driving at 70. It looks so calm in the picture but I bet it wasn't so quiet in the drivers seat! How's it look HJ?
xxemaphorr
Re: rev counter
Post by HighlyJetted on Mon Sep 02, 2013 5:56 pm
Hard to get any pictures as my van is parked into the afternoon sun.
Well easy to install though, took about 20 minutes start to finish.
I cut a spare dashboard surround I had knocking about, and I cut it with a pneumatic die grinder.
Re: rev counter
Post by HIJET1300GT on Mon Sep 02, 2013 6:05 pm
Looks gooood . Now you have that your mpg will go out the window!
HIJET1300GT
Re: rev counter
Post by HighlyJetted on Mon Sep 02, 2013 6:25 pm
Re: rev counter
Post by HIJET1300GT on Mon Sep 02, 2013 6:58 pm
Pmsl ! love it . I'd love to see a hijet spoof of that clip.
HIJET1300GT
Re: rev counter
Post by HighlyJetted on Mon Sep 02, 2013 10:30 pm
All the way baby..... 5800rpm  Laughing
I think you'd get 7000rpm out of a 1300 hijet
Re: rev counter
Post by HighlyJetted on Mon Sep 02, 2013 11:01 pm
Which reminds me, I have to move my rev counter as I can't see it very well.
Re: rev counter
Post by HIJET1300GT on Tue Sep 03, 2013 6:50 am
We're you going to put it?
HIJET1300GT
Re: rev counter
Post by Guest on Wed Sep 04, 2013 10:08 pm
My two Rev Counters arrived safe and sound today, well pleased with them and the fast service.
Re: rev counter
Post by HighlyJetted on Wed Sep 04, 2013 10:21 pm
I would take some pictures of my new gauge installs but it's dark as fook.
Re: rev counter
Post by rich the mechanic on Wed Sep 04, 2013 10:38 pm
Just out of interest what setting should I use on my multimeter to look for the tacho signal? I have a couple of conectors with nowt attached under the dash other than the diagnostic on and never found a voltage output from any no matter what I turn on or off just wondering if I should try a different setting, I have had a little look at the wiring diagram but not traced them there either.
Re: rev counter
Post by HighlyJetted on Wed Sep 04, 2013 10:44 pm
Tacho signal will be a pulse, so you need a multimeter that does frequency and/or duty cycle. Normally measured in Hz
It's not the most common of features, unless you have a slightly more feature rich meter.
Re: rev counter
Post by rich the mechanic on Wed Sep 04, 2013 10:50 pm
I cant remember if Hz is on there defo no duty cycle but I think the one at work has a few more fetures might need to borrow it.
Re: rev counter
Post by HighlyJetted on Wed Sep 04, 2013 10:59 pm
On a 993cc you should just be able to connect it up to the coil.
The 1.3 vans have a pair of coils so it makes life a little more complex, but since the tacho out feed from the ecu has been discovered on the diagnostic connector it makes it a breeze.
Re: rev counter
Post by Guest on Thu Sep 05, 2013 6:45 am
But you have only got 3 pulses per two revolutions 4 per two revolutions
on a 13000. You can switch to 4,6 or8 on the tacho .Using it on 4 cylinder
it will read 25% slow and on 6 50% slow. Or am I missing something here?
Re: rev counter
Post by Logi on Thu Sep 05, 2013 9:11 am
Just looking at the pics of the install next to the clocks, WTF is that bit of the dash for anyway? Why does it have that useless wee cubby hole thing at the side of the speedo? I just never understood why the bit existed.
Re: rev counter
Post by HighlyJetted on Thu Sep 05, 2013 9:39 am
woody wrote:But you have only got 3 pulses per two revolutions  4 per two revolutions
You need a rev counter that does three cylinder signals Wink
Your guess is as good as mine Logi, the mystery slot???
Re: rev counter
Post by HIJET1300GT on Thu Sep 05, 2013 11:45 am
The mystery slot, the mystery being how would anything stay in there. I can imagine it was the same person came up with the coin holder by the hand brake ! I used it once , at the end of my journey I had to retrieve my change from both footwells and from under my seat! Fail.
HIJET1300GT
Re: rev counter
Post by HighlyJetted on Thu Sep 05, 2013 12:52 pm
Ha, I nearly mentioned the coin holder in the "mystery slot" post.
Bloody great interior design work in these vans.
A clock would have been nice.
Re: rev counter
Post by HIJET1300GT on Thu Sep 05, 2013 1:05 pm
Why give you one when they can charge you as an optional extra ! I got one in the box off eBay , it goes in the useless radio slot.
HIJET1300GT
Re: rev counter
Post by HighlyJetted on Thu Sep 05, 2013 1:07 pm
I've put my radio in the useless radio slot
Re: rev counter
Post by HIJET1300GT on Thu Sep 05, 2013 1:27 pm
I've gone for the clock option , I couldn't get my 8Track in that poxy hole!
HIJET1300GT
Re: rev counter
Post by Logi on Thu Sep 05, 2013 3:29 pm
I actually have a plan for the useless coin holder, that's where i'm mounting the switches for the electric windows Smile
Re: rev counter
Post by HighlyJetted on Thu Sep 05, 2013 3:33 pm
This I have to see, I just want one for the passenger side.
Re: rev counter
Post by Guest on Thu Sep 05, 2013 5:12 pm
Thank you HJ. That was my point that the revcounter is not usable for all who own 3 cylinder models. Its only useable on the 1300's.
Re: rev counter
