sliding door top track/run fooked
Post by leopard_pagan on Sat Aug 31, 2013 10:52 pm
since i got it the sliding doors havnt run smooth. got new bearings with the intention of sorting them....
today the top LHS door opened but got stuck half way... a 3" section of the top runner/track is missing & the bearing holder bit wouldnt move..
with a screwdriver & brawn.. managed to get the door shut.
now where on earth do i start with this repair?
Door off for sure...
can i weld a new run on?
can you replace the whole run/track? Suspect
Re: sliding door top track/run fooked
Post by HIJET1300GT on Sat Aug 31, 2013 11:20 pm
has it worn away or rotted away? sounds like a welding job LP
HIJET1300GT
Post by elfin girl on Sat Aug 31, 2013 11:27 pm
i have a 3" gap in my top runner too that somehow caught the bearings when i tried to slide it shut and the door fell on my head! mine looks cut tho, presumably its the bit that allows the door to be taken off, i just shut it very carefully now!
Post by leopard_pagan on Sun Sep 01, 2013 10:19 am
had a better look in daylight.
there is a chunk missing from the outer part of the track which lets the runner out!
I have also noticed that the track is Tack welded in place front passenger pillar end, but cant see how its attached other end?
If so whats to stop me drilling the weld out... & riveting a new rail in?
pics below..
Post by HIJET1300GT on Sun Sep 01, 2013 10:27 am
That's spose to be there I had a look at mine , the problem might be else were . My upper rollers sit high the that Chan so may be the problem could be with the lower roller or arm that holds it Bent ect?
HIJET1300GT
Post by HIJET1300GT on Sun Sep 01, 2013 10:30 am
Bend that bit back first tho and tack it.
HIJET1300GT
Post by HIJET1300GT on Sun Sep 01, 2013 10:40 am
Had a look at my lower arm . There is some adjustment to get it higher and also bring that lower roller more inboard on the lower runner to stop it falling off the edge of it .
HIJET1300GT
Post by HighlyJetted on Sun Sep 01, 2013 10:52 am
Yeah, that slot should be there.
As said before, bend it back to straight with some slip joint pliers or mole grips etc.
GT has is nailed really, bit of adjustment to stop it dropping out and your laughing.
Post by leopard_pagan on Sun Sep 01, 2013 8:58 pm
Righto.... Will pilfer some molegrips & see if I can strengthen it next few days
Post by leopard_pagan on Mon Sep 02, 2013 4:26 pm
Bent it back & the top runner is still coming out as the passes the gap.
someone mentioned Adjusting the door UP...?
how?
Post by HighlyJetted on Mon Sep 02, 2013 5:58 pm
With the bottom runner. There are some bolts on the arm that clamp the two sections together.
