Those with late type....
Post by rich the mechanic on Sun Sep 01, 2013 6:58 pm
.... ECU's did you know you could get one of these http://www.ebay.co.uk/itm/Bluetooth-Android-Torque-Car-V1-5-ELM327-OBD2-OBDII-Diagnostic-Code-Scanner-UK-/321149933981?pt=UK_Diagnostic_Tools_Equipment&hash=item4ac607199d and you can get an App for your smart phone to run live data on the move I'm sure a few tec heads would like it.
Re: Those with late type....
Post by HighlyJetted on Sun Sep 01, 2013 8:35 pm
Yeah I've used other peoples ones of them, and they are a bit hit and miss. Some of the blue tooth modules don't seem to work very well with the obd2 protocols, and the blue tooth communication protocols are poorly implemented.
The various android software downloads are a bit amateur. But I believe there is a better one for Iphones, but I've never tried it.
Yes it is a cool idea though!!!
Post by rich the mechanic on Sun Sep 01, 2013 8:56 pm
I came across an app to make a scanner using your phone first I had seen of it thought it a good idea for someone like me as I don't work on modern stuff very often (if I can help it) then found out how it was all linked up and no good for me.
