MOT tomorrow
MOT tomorrow
Post by HighlyJetted on Sun Sep 08, 2013 8:46 pm
8:30am MOT Monday morning... totally forgot about it with a heavy weekend.
Last minute prep work i'm going to do after I eat my tea is:-
Change wheels and tyres for a another good set as my rears are on the limit.
Swap steering wheel over as I have no horn button Embarassed
Tweak rear brake bias controller as the back brakes barely do anything, then chuck a load of heavy stuff in the back.
Check all bulbs, wipers, washer jets.
Wish me luck!
Re: MOT tomorrow
Post by HighlyJetted on Sun Sep 08, 2013 10:06 pm
My fuel tank is leaking Sad
Re: MOT tomorrow
Post by d1noh on Sun Sep 08, 2013 10:28 pm
early start then? only a hour to change, bet you sold all your spare ones
Re: MOT tomorrow
Post by d1noh on Sun Sep 08, 2013 10:30 pm
or just leave enough in it for the test Smile
Re: MOT tomorrow
Post by HighlyJetted on Sun Sep 08, 2013 10:58 pm
I haven't seen a great tank yet.
If he fails it, I'll take it off, and weld a plate on the bottom.
Or I'll cover it in epoxy resin and tin foil Laughing
Re: MOT tomorrow
Post by Guest on Sun Sep 08, 2013 11:59 pm
That really is a bit of bad luck Matt. Couldn't be much worse timing.
That's why I try and hold a stock level for myself and say no when I reach
it coz it really is Murphy's law when you get rid of your last spare--
You always need it yourself. And no I am not sending you a tank after
that last one I spent a week wrapping up to send out. What a pig of a job.
I have been welding up a bike tank this morning. The whole lower
rear corner was like rice paper. Built it right up though and it looks really
good. Well pleased with my efforts.
Second one I have done I a month. Word is getting round in the Biking
fraternity too it seems.
Anyway good luck with the rest of the Mot .
Re: MOT tomorrow
Post by HighlyJetted on Mon Sep 09, 2013 12:40 pm
Failed on fuel tank and brake lines Sad
Re: MOT tomorrow
Post by Guest on Mon Sep 09, 2013 12:51 pm
Oh Poooo!!! More work needed then.
Re: MOT tomorrow
Post by HighlyJetted on Mon Sep 09, 2013 12:57 pm
Just finished eating my dinner while I gear myself up to get cracking....
Oh how I love crawling underneath a Hijet Rolling Eyes
Re: MOT tomorrow
Post by Lab_Rat835 on Mon Sep 09, 2013 2:24 pm
brake lines and fuel tank is not too bad, could have been a lot worse
Lab_Rat835
Re: MOT tomorrow
Post by singledad on Mon Sep 09, 2013 8:41 pm
i used a plastic padding fuel tank leak fix worked well got through mot but got a leak higher up now
singledad
Re: MOT tomorrow
Post by d1noh on Mon Sep 09, 2013 8:49 pm
Time to put a alloy tank where the spare wheel/LPG goes, got the bracket to put the spare inside if you need one
Re: MOT tomorrow
Post by HighlyJetted on Mon Sep 09, 2013 9:04 pm
Spent a couple of hours trying to weld up the tank, but there is just nothing there to weld, the steel is like a sieve. It's so thin in places you can just push a screw driver through it. Ground it all back to find non rotten steel... but there is not much of it anywhere. Total waste of time, I have got another tank that doesn't leak but its not much better and wont last that long. I might use this one temporary then mould myself a new one out of plastic. Alloy tank is a nice idea, but after buying one for the pickup and the other hardware to fit it I'm not digging that deep again for this work horse van.
Just to put the icing on the cake, just after I got my fail sheet I get a phone call..... "Have you got a fuel tank for hijet van"
I had a little chuckle at the irony of it!
Re: MOT tomorrow
Post by d1noh on Mon Sep 09, 2013 9:17 pm
Re: MOT tomorrow
Post by HighlyJetted on Mon Sep 09, 2013 10:39 pm
Wonder if I should lead my fuel tank scratch
Re: MOT tomorrow
Post by Lab_Rat835 on Mon Sep 09, 2013 11:15 pm
duct tape is the answer to everything unless its 42 but thats a diffrent question entirely
Lab_Rat835
Re: MOT tomorrow
Post by Guest on Tue Sep 10, 2013 12:30 am
42 is Special Fried Rice on our local Chinese Takeaway Munu Razz . Go to sleep now for goodness sake. It's way past your bedtime. You wont be up in time for School at this rate.
You are keeping me up and I am up at 6am. affraid
Re: MOT tomorrow
Post by eddie0303 on Tue Sep 10, 2013 8:28 am
It sounds like another common fault , to add to the list of Hijet problems . I will be taking mine off as soon as possible now to give it a clean and coat of underseal .
Can I now just clarify something , the wiring looms are crap , the petrol tanks leak , they overheat , they all have common rust points , they dont give very good MPG and getting parts can be difficult .
WHY THE HELL DID WE BUY THEM ? Very Happy Very Happy Very Happy Very Happy
Eddie .
eddie0303
Re: MOT tomorrow
Post by HighlyJetted on Tue Sep 10, 2013 8:54 am
Hey hey hey, calm down... they do give pretty good MPG and parts are pretty cheap once you know where to find them.
I know why I drive one, because I prefer to be the tosser in the noddy van than the cock end in the average car.
Plus I can fit a fridge freezer or a motorbike or a sofa or 3 dogs and a prostitute in the back.
Which reminds me, I must hoover out the back of my van.
Re: MOT tomorrow
Post by Lab_Rat835 on Tue Sep 10, 2013 12:33 pm
i am thinking imight have to get mine in the air and get happy with the schuts gun
Lab_Rat835
Re: MOT tomorrow
Post by HighlyJetted on Tue Sep 10, 2013 2:26 pm
Hiding won't solve it in the long run. Arches and sills tend to rot from the inside out on a Hijet
Brake lines on the other hand, well hiding them does help with MOT's for a bit!
Problem with schutz is its an arse to fix things afterwards when everything is coating with the minging crap.
Mine are redone in copper now, so should out last the van.
If your fuel tank doesn't leak, I would highly recommend coating it with something. I will be doing mine asap.
Re: MOT tomorrow
Post by HighlyJetted on Tue Sep 10, 2013 4:49 pm
Waiting for the retest now......
Re: MOT tomorrow
Post by HighlyJetted on Tue Sep 10, 2013 5:18 pm
Road legal once again
Re: MOT tomorrow
Post by eddie0303 on Tue Sep 10, 2013 6:46 pm
The mind boggles why you would want 3 dogs in the van , when you already have a prostitute and a settee . Very Happy
Must be one of those dogging trips you mentioned . Very Happy
Cheers
Eddie
eddie0303
Re: MOT tomorrow
