Fuel tank protection
Post by Mini-deli on Fri Sep 20, 2013 11:50 pm
Has anyone designed and made a fuel tank guard?
I was having an underside poke around and noticed quite a large dent in the tank!
Mmmmm I thought - that looks like it needs a guard.
If not I will just design and make one myself.
Just thought that a proven design would save me a bit of mucking about.... Smile
Marcus
Mini-deli
Re: Fuel tank protection
Post by HighlyJetted on Sat Sep 21, 2013 12:26 am
I took one tank apart to find the bottom had dented in.
Which had bent the fuel gauge float tube assembly.
No wonder it no longer worked!
Wonder how common that is!!
Post by Mini-deli on Sat Sep 21, 2013 10:09 am
Looking at it, the tank is very venerable to impacts.
I really don't like that. I think I will probably use some tread plate - easy to source and tough stuff.
It will be a while before I can get on to it..... but I will get on to it.... Smile
I will be dropping the tank out anyway to do a re-furb' and anti-corrosion coating etc.
Marcus
Mini-deli
Post by singledad on Mon Sep 23, 2013 12:44 pm
think someone should produce plastic replacement tanks there must be a market for them
singledad
Post by HighlyJetted on Mon Sep 23, 2013 1:06 pm
Plastic tanks have issues with some of the new fuels being dished out at the fuel pumps.
Lots of car manufactures are having problems in some countries where the ethanol content is increasing.
Plastics are not stable to petrol/ethanol mixes.
