As Requested...... The 4wd system
Post by d1noh on Sat Sep 21, 2013 8:12 pm
Front Diff
Front Diff
Front Diff
Cross Member
Cross Member
Gearbox different output shaft
Shorter damper/spring
Splind Hub
Front Crossmember
Cat and shaft
Shaft going under the engine carrier
Front Diff
No copy exhausts are availabe
Transfer box
Cat has more angle to send it around the shaft
Rear prop
Re: As Requested...... The 4wd system
Post by PFM on Sat Sep 21, 2013 8:58 pm
Very interesting set of pics there, thanks. You didn't have to go so far as to dis-assemble it to get the pics of the front diff and crossmember though Very Happy
Post by d1noh on Sat Sep 21, 2013 9:11 pm
Not a problem, anyting to help
lol!
Post by HighlyJetted on Sat Sep 21, 2013 11:20 pm
That is very interesting indeed.
The Terios front diff is the same unit but it has a different rear plate on it.
And the terios transfer box is the same too.
So someone really wanting to do the conversion could do it, but they would have to fabricate their own brackets for the diff.
Modify the terios front prop shaft.
Modify the terios front drive shafts and find suitable CV joints for the Hijet hubs. (someone should have 4x4 hijet CV joints available?! maybe?!)
Mix and match the terios gearbox with the hijet gearbox.
Resolve the exhaust routing issue.
Modify the hijet dampers so they don't stick out in the way of the drive shafts. (cut bracket off, reweld, then get some damper inserts maybe?)
Well that's a start anyway!
Post by d1noh on Sat Sep 21, 2013 11:32 pm
What are the implications of doing a 2wd auto? is it just a box and linkage change?
Post by HighlyJetted on Sat Sep 21, 2013 11:34 pm
Now thats a question!........
give me a minute or two.....
Post by HighlyJetted on Sat Sep 21, 2013 11:55 pm
Right from a really quick dig on the terios gearbox.
I think the Automatic terios was from 2000 onwards when they changed over to the toyota 1.3 engine not the HC-E like the hijet.
So the gearbox bell housing MAY be different. Also keep in mind the terios does not have the lean over engine design. So even if the gearbox did bolt on, it would not work as it won't be leant over so the gearbox oil pump/sump/pickup pipe will be all incorrect for gravity/oil.
Looking at this diagram from the terios manual, the automatic gearbox does not have a separate bell housing. So you can't just mix and match to suit.
Obviously with any auto gearbox you will have to look at the oil cooler setup and the shifter lever etc.
Post by d1noh on Sun Sep 22, 2013 12:00 am
intresting, love a Auto
Post by HighlyJetted on Sun Sep 22, 2013 12:13 am
I can understand why! Would make your life much less hard work without clutching and shifting.
Post by Guest on Sun Sep 22, 2013 6:40 am
Would totally spoil the fun defininitely HJ. Automatic are are only for old
Grandads over the age of 60------ Sad Sad Laughing Laughing  Oh sugar -- surely can't mean me too. I am still a kid at heart.
Post by HighlyJetted on Sun Sep 22, 2013 10:09 am
It's what he does with them...
Remember the discussion about fuel economy, and Dino measures his in gallons per hour Laughing
