door bits wanted
door bits wanted
Post by simmo116 on Mon Sep 23, 2013 6:16 pm
hi guys. am in need of the little screws that hold the bearings on the runner. bearings turned up today only took 3 weeks lol
think I only need a couple. would anyone happen to know what there called and where I could get some from.
thanx
rich
simmo116
Re: door bits wanted
Post by HighlyJetted on Mon Sep 23, 2013 6:19 pm
What is wrong with the screws you've got?
I have some by all means!
Post by HighlyJetted on Mon Sep 23, 2013 6:23 pm
The whole setup looks like this,
The gold bolt and tube hold the bearing on.
http://www.daihatsuhijet.co.uk/repair-hijet-sliding-doors-rough-sticking-grinding-bearings-dropped/
Post by simmo116 on Mon Sep 23, 2013 7:02 pm
ok so I have the bearing thingy with gold screw but am in need of a complete one of those at the bottom right of picture.
least of my troubles though at moment as having water pump issues. have just discovered that I cant take off pump with timing belt still on. and most annoyingly all the hose clips have obviously been put on from underneath the van. pain in the ar*e when you not got a ramp.
am a complete novice by the way if you couldn't tell.
plumber/pipe fitter by trade so not a complete muppet when it comes to technical stuff.
simmo116
Post by HighlyJetted on Mon Sep 23, 2013 7:05 pm
What engine is it?
Post by PFM on Mon Sep 23, 2013 7:13 pm
He has the 993 and yes, you do have to take the belt off but only at the top IIRC, so a chalk mark on belt and cog should suffice.
Post by simmo116 on Mon Sep 23, 2013 7:16 pm
where do I release the tension on the belt guys?
simmo116
Post by HighlyJetted on Mon Sep 23, 2013 7:19 pm
Post by HighlyJetted on Mon Sep 23, 2013 7:22 pm
Post by simmo116 on Mon Sep 23, 2013 7:53 pm
so I just pull on number 7 to release the tension. how much play should there be btw?
did try a spanner on it but couldn't get it to move. will try again tomoz.
simmo116
Post by HighlyJetted on Mon Sep 23, 2013 8:00 pm
Yep, loosen the bolt, then it will just be tensioned by the spring.
Post by simmo116 on Mon Sep 23, 2013 8:11 pm
Brill will give it a go tomorrow.I think the hard part is putting it all back together lol just got loads of bits and bucket of nuts and bolts.
simmo116
Post by simmo116 on Tue Sep 24, 2013 6:38 am
Hi HJ, did you mention you had one of those vertical runner thingy ma Bob's?
How much are they mate.?
simmo116
Post by HighlyJetted on Tue Sep 24, 2013 11:11 am
It's more for the labour of actually sorting it out and getting the posted but £3 for a pair of them and £2 for postage.
Just paypal me at threepot@hotmail.co.uk and put your postal address on the paypal info if it isn't already!
