Brake Servo
Brake Servo
Post by eddie0303 on Fri Sep 27, 2013 5:16 pm
Hi All , I have noticed a damp area around the ridge of the servo and although the van has not been on the road as yet , I wondered if they are also prone to servo leaks , I can see that the fluid is eating away at the paint affraid  so it has to be brake fluid although my fingers are crossed that its just a bit of over spill from when I topped up the reservoir . If the worst comes , are they difficult to replace and whats the best source of replacement ,and cost please . Hoping Matt or Woody may have a spare if needed . ( Fingers crossed ) . Sad
Cheers All
Eddie
eddie0303
Re: Brake Servo
Post by HighlyJetted on Fri Sep 27, 2013 5:25 pm
Brake master cylinders are prone to leaking. Sold 3 in the last couple of months - and I have non left at the moment.
Pretty easy job to change, just have to remove the dashboard.
Daihatsu want £800 for the master cylinder and servo assembly one customer told me!!!!!!
They also told me non of the motor factors could supply one.
Re: Brake Servo
Post by Guest on Fri Sep 27, 2013 6:21 pm
How many would you like Eddie ?? Dunno where Daihatsu conjure up their prices from!!!
Anyway several on the shelf Edd.Very Happy Very Happy Very Happy Very Happy .
 You've got my number -- give me a call anytime after nine. Should be home from the garage by then .
Re: Brake Servo
Post by Logi on Fri Sep 27, 2013 7:31 pm
You don't even have to remove the dash either Wink
Re: Brake Servo
Post by HighlyJetted on Fri Sep 27, 2013 11:42 pm
I guess not actually come to think about it.
I've always had the dash removed to strip everything out before I removed the master cylinder.
Re: Brake Servo
Post by Logi on Sat Sep 28, 2013 5:38 am
Changed mine in the old van, its fiddly bit doable, hardest part is reconnecting the reservoir hoses.
Re: Brake Servo
