Photobucket - so easy
Page 2 of 2 Previous  1, 2
Re: Photobucket - so easy
Post by Guest on Sat Sep 28, 2013 10:53 am
Trouble is Photo bucket has given up on me ..
I get to the last bit where all the relevant text is supposed to appear and it does a Paul Daniels on me---- a disappearing trick.
Obviously it WAS working for me--- now it's not.
Post by leopard_pagan on Sat Sep 28, 2013 11:31 am
Photobucket doesnt like files with the same file name... it has posted 2 different files as the 1st i uploaded.
BUT Photobucket DOES WORK..
Practise makes perfect boys... back in the day.. even i had to figure out how this internet stuff worked..
Post by Guest on Sat Sep 28, 2013 11:57 am
Thank you LP. I can suss what is happening there with certain pictures as you are right some are in two files and appear two pictures the same next to each other with two TOTALLY different
ID numbers.
I have over 7000 pictures on my camera and a lot more on the laptop and on a couple of occasions has doubled up into two different storage areas on the
Laptop. How the hell do I sort that out?
Time to contact my number two son to let him sort that.
What I will try tonight is send pictures that are definitely in one
folder or rather than use a monthly folder use one from a date only source and try that.
Thank you LP.
Post by Guest on Sat Sep 28, 2013 8:28 pm
melboy wrote:woody at least you managed to put some pictures on,ive given up trying.Embarassed
Well I am damn well not giving in this time. I am going to get the mastrery of it. Will try later. Had just 150 mins sleep last night and I have just got back from the garage so after a soak in the bath and some dinner I will have another go.
Post by Mini-deli on Sun Sep 29, 2013 12:04 am
Set up a new account and start again.......
It really IS easy as said...
This is part of a step thru for my Deli -
Very easy to do.....
I will be doing same for Hijet in time as I take on tasks.... Smile
Mini-deli
Post by Mini-deli on Sun Sep 29, 2013 12:06 am
That is the whole front drive taken out - on my own....and re-fitted....This baby will be easy..... Smile
Mini-deli
Post by Mini-deli on Sun Sep 29, 2013 12:14 am
The bricks and wooden member are just a safety thing.....
I had a 3lt V6 drop on me .......I had just got out....a second later it went.
Jack went thru sump.....big hole.....
Safety guys - safety....
Don't go under unless you feel safe.....
Mini-deli
Post by Guest on Sun Sep 29, 2013 6:16 am
I did try what you suggested Del Boy --- but it was a non starter.
What I was seeing on my laptop was nothing like you described.
I think if you read back you will see that LP may well have found part of my problem --- but it still doesn't explain WHY pictures are repeating themselves
AND why the three pictures I posted for Matt's benefit came out on my Tablet,
but not on my Laptop.
Work that one out and tell me your easi-peasi answer to that one Del.
I will nominate you for Mastermind if you can sort that one out. scratch scratch Regards Woody.
Post by Mini-deli on Sun Sep 29, 2013 9:21 pm
Mmmmmm
Now that really is puzzling..................
I can't even begin to explain that one!
Marcus
Mini-deli
Post by Guest on Sun Sep 29, 2013 11:56 pm
Flipping weird that one!! Not logical at all.
