My first hijet!
Re: My first hijet!
Post by HighlyJetted on Sun Oct 06, 2013 6:56 pm
Before you spend a penny on that.
Make sure it runs ok.
Re: My first hijet!
Post by Rodders on Sun Oct 06, 2013 7:02 pm
Im getting electric power. Lights on dash but no turn over of engine.
Not sure if its the starter or solinoid?
Rodders
Re: My first hijet!
Post by d1noh on Sun Oct 06, 2013 7:07 pm
have you conected both of the positive leads to the battery?
Re: My first hijet!
Post by Rodders on Sun Oct 06, 2013 7:11 pm
Ive connected positive and negative leads to battery. Thats how i got the power to dash.
Unless the van has two positives? Then no.
I couldnt see another positive?
Rodders
Re: My first hijet!
Post by HighlyJetted on Sun Oct 06, 2013 7:19 pm
Does the engine light come on and the fuel pump pump make noise when you turn the key to the on point.
Re: My first hijet!
Post by Rodders on Sun Oct 06, 2013 7:24 pm
The engine light is on and fuel pump made noise.
It might be solinoid?
Rodders
Re: My first hijet!
Post by HighlyJetted on Sun Oct 06, 2013 7:35 pm
Well, now you need to diagnose just that issue.
First, use a multimeter on the starter motor - make sure you get 12v at the little wire when you turn on the key - this is the "activator" wire.
Then make sure you get 12v at the big wire.
If both is true the I would suspect the starter motor.
How are you powering it?
Re: My first hijet!
Post by Rodders on Sun Oct 06, 2013 7:37 pm
HighlyJetted wrote:Well, now you need to diagnose just that issue.
Thankyou:)
Do you meen powering it by battery?
Rodders
Re: My first hijet!
Post by HighlyJetted on Sun Oct 06, 2013 7:42 pm
So then how old is the battery? How well charged is it?
Have you tried starting it on some jump leads?
Re: My first hijet!
Post by Rodders on Sun Oct 06, 2013 7:47 pm
HighlyJetted wrote:So then how old is the battery? How well charged is it?
Have you tried starting in some jump leads?
The battery in it didnt work at all. So i took out my mini battery (car i use every day) and attached it to the hijet.
Rodders
Re: My first hijet!
Post by HighlyJetted on Sun Oct 06, 2013 7:57 pm
On the live terminal, there is another cable that joins it, and then that goes to a grey plug thing where is splits into 2.
Mess with that lot while you hold the key on for start.
After that, try hitting the starter motor while you hold the key.
Then test the voltages out as described.
If all that goes ok, take the starter motor off and bench test it.
But if you can't be arse with all that. Drag the van down the road on a length of rope to see if you can bump start it.
Re: My first hijet!
Post by Rodders on Sun Oct 06, 2013 9:21 pm
HighlyJetted wrote:On the live terminal, there is another cable that joins it, and then that goes to a grey plug thing where is splits into 2.
I will try that tomorrow. Cheers
Rodders
Re: My first hijet!
Post by Rodders on Mon Oct 07, 2013 6:58 pm
So i tested the solinoid on starter motot perm live thats good. Then the spade connector which goes to ignition thats negitive. But stay negative when ing and start up goes on.
So i got a piece of wire and put it from the perm live on solinoid to the other spade wire coming out and it turned over the starter motor.
So could it be the wire from the solinoid to ignition thats bad?
Rodders
Re: My first hijet!
Post by HighlyJetted on Mon Oct 07, 2013 7:52 pm
Make sure the final switching stage of the ignition barrel works.
If your getting the starter live there, then you can work forwards.
Re: My first hijet!
Post by Rodders on Mon Oct 07, 2013 8:02 pm
HighlyJetted wrote:Make sure the final switching stage of the ignition barrel works.
Where is the final switching stage of the ing barrel?
Rodders
Re: My first hijet!
Post by d1noh on Mon Oct 07, 2013 8:24 pm
in the ign switch/barrel it has 2 ignition + aswell a as aux
Re: My first hijet!
Post by Rodders on Mon Oct 07, 2013 8:27 pm
There are 4 or 5 wires coming off the barrel.
I did check them but not sure if i got the right result.
How many do i need live and how many negative?
One showed no live or negative.
Rodders
Re: My first hijet!
Post by HighlyJetted on Mon Oct 07, 2013 8:55 pm
I'm sure if you sit and think about it you will work out how the ignition barrel works!
Its here on the diagram:-
http://www.daihatsuhijet.co.uk/pdf_manuals/Workshop%20Manual%20-%20PORTER%201.3%2016V%20-%20Electrical.pdf
Sort of top left, "IG SW"
Re: My first hijet!
Post by Rodders on Mon Oct 07, 2013 9:02 pm
Ok cool.
Also there is a thick cable that is at the front of the van. That has a grey plug/connector with a green band on that has two wires blue and white and red and white is this anything important as its not plugged in and i cant find where it goes.
Rodders
Re: My first hijet!
Post by HighlyJetted on Mon Oct 07, 2013 9:10 pm
photos really help Wink
Re: My first hijet!
Post by Rodders on Mon Oct 07, 2013 9:19 pm
Ok i will take some pics tomorrow:)
Rodders
Re: My first hijet!
Post by HighlyJetted on Mon Oct 07, 2013 9:22 pm
If you took pictures of all the loose wires, I could pretty much tell you what they should all plug into Laughing I need a life!!
Re: My first hijet!
Post by Rodders on Mon Oct 07, 2013 9:24 pm
HighlyJetted wrote:If you took pictures of all the loose wires, I could pretty much tell you what they should all plug into Laughing I need a life!!
Lol ok i will take as many to show what i cant figure out. Smile
Rodders
Re: My first hijet!
Post by Rodders on Mon Oct 07, 2013 9:48 pm
Im going to buy a 2wd van and convert it to 4wd.
I dont know how long it will take but i think its the best. And from some very good advise its sensible.
Rodders
Re: My first hijet!
Post by Rodders on Sat Oct 12, 2013 11:54 am
Right so the van is working. Yay!!
I just have to find where the fault is from the ign barrell to the starter motor.
And still have to source another van.
Then it will be on the road.
Rodders
Re: My first hijet!
Post by Rodders on Sun Oct 20, 2013 2:03 pm
Right so i took all the bits out of the back of the van.
Drained all the fuel and oil out.
Started the cutting.
https://redcdn.net/ihimg/a/img11/5452/f7j7.jpg
https://redcdn.net/ihimg/a/img194/7485/qz1x.jpg
Roof off
https://redcdn.net/ihimg/a/img266/4497/7zzj.jpg
All of this on my own.
Rodders
Re: My first hijet!
Post by Logi on Sun Oct 20, 2013 2:14 pm
Wow! A convertible Hijet and a sledge!! Smile
Re: My first hijet!
Post by Rodders on Sun Oct 20, 2013 2:28 pm
Ready for winter!Smile
Rodders
Re: My first hijet!
Post by Rodders on Sun Nov 10, 2013 2:20 pm
After all searching.
Im now going to be selling my van.
Ive bitten off more than i can chew. I also realise i dont have the time and space to do it properly:(
Rodders
Re: My first hijet!
Post by Logi on Sun Nov 10, 2013 5:23 pm
Rodders wrote:.I dont want to sell the van after fixing it.. Smile
Just before... Shocked
Re: My first hijet!
