fast running van
fast running van
Post by DonnyMacdonald on Fri Oct 18, 2013 2:44 pm
Hi All bit of infomation needed changed the engine on one of my vans (due to head gasget being blown) everything went ok but the van runs fast I expect its the choke but were do I go about adjusting it and is it an automatic choke one that adjusts itself thanks guys
DonnyMacdonald
Re: fast running van
Post by HighlyJetted on Fri Oct 18, 2013 3:14 pm
2 things cause this.
Either a vacuum leak somewhere on the inlet manifold e.g. a broken hose, leaking gasket or rubber etc
Or the idle control valve is not getting water through it. - make sure the two water hoses (feed and return) are getting hot, if not then thats your problem.
