Mot Fail....
Mot Fail....
Post by Glasgowjet on Sat Oct 19, 2013 5:19 pm
Hi Folks,
I ran my van through a Mot this morning to give me an idea of what shape it's in as I haven't had time to go over it in detail.
So needles to say it failed so here is the reasons for refusal below your thoughts would be great.
Nearside headlamp aim too low
fuel system component leaking ( tester said that it's the fuel filter and the pipes that go into it that are heavily corroded )
Rear (at compensator) brake pipe corroded
Rear flexi-hose brake pipe corroded
Front pads and Discs excessively worn.
ADVISORY ITEMS...............
Both rear shock absorbers worn and bushes perished and split
Both rear leaf springs heavily corroded and weakend
Both headlamps - inside reflective coating corroded.
The weather is shocking today so I can't get a good look around it but I have a nice wee list to get through Shocked
Glasgowjet
Re: Mot Fail....
Post by Logi on Sat Oct 19, 2013 5:25 pm
Glasgowjet wrote:Hi Folks,
Adjust it?
Get a pickup filter and some high pressure fuel hose, cut the rotten stuff out and connect it up
Pretty usual, awkward, but not difficult
As above
Piece of piss
Insulating tape wrapped round the old bushes
Wire brush(Dettol optional....)
Yep.... Good luck....
Shocked
Re: Mot Fail....
Post by Glasgowjet on Sat Oct 19, 2013 5:41 pm
Cheers Logi apart from the pick up fuel filter pretty much what I was thinking.....Wink
Glasgowjet
Re: Mot Fail....
Post by HighlyJetted on Sat Oct 19, 2013 6:06 pm
Ahh, a typical Hijet fail list.
Sorting that fuel pipe issue will kill 2 birds - fuel consumption and an MOT certificate.
Rear brake pipes - that's bit of an arse but easy job if you know how, and have a copper flare kit.
Front brakes - well sounds like you need them, and with the above, its time to put fresh brake fluid through the whole system
Adjust your head light.
Job done
Re: Mot Fail....
